auto wap - JeepForum.com
post #1 of 10 Old 01-07-2014, 06:46 PM Thread Starter
caddynut
auto wap
what is the difference between a 87 auto and a 91 auto
caddynut is offline
post #2 of 10 Old 01-07-2014, 10:06 PM
Soldier905
1988 MJ Comanche
You will need to put down more information than to get a good answer .
Soldier905 is offline
post #3 of 10 Old 01-08-2014, 11:11 AM
87MJTim
1987 MJ Comanche
What are the current engines and trans? (Trans: 3sp or 4sp?)
Those will effect the ability to swap.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.2, AX15 (Formerly T5)
87MJTim is offline
post #4 of 10 Old 01-08-2014, 08:39 PM
Caish
1987 XJ Cherokee
91 was the first year of the HO in a Cherokee did it ever make it into a Comanche?? .
The only automatic used on the 4.0L Comanche is a AW4 that I know of.
Now is the TCM module the same on a REnix and HO I have no idea.
But I'm betting they are the same.
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
post #5 of 10 Old 01-08-2014, 08:48 PM
87MJTim
1987 MJ Comanche
AFAIK the only diffs between the MJ & XJ are behind the driver's seat. The engines/trans are the same for both for the years.
Tim
87MJTim is offline
post #6 of 10 Old 01-10-2014, 06:32 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Different output shafts and spline count.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #7 of 10 Old 01-10-2014, 06:34 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
YES. .
YES
NOT
Ask Paradise about tCUs. He had a heck of a time and that ended up being the issue.
post #8 of 10 Old 01-10-2014, 07:32 PM Thread Starter
caddynut
sorry 87 4.0 4spd auto 4x4 / 91 4.0 4spd auto 4x4
caddynut is offline
post #9 of 10 Old 01-10-2014, 07:38 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Spline count.
post #10 of 10 Old 01-14-2014, 02:50 PM
uberxj92
1992 XJ Cherokee
Spline count and tcu and bell housing is a little shallower on the renix.
Just went thru this on my 92 xj. Put in a built fresh 90 aw4. Had to use the 92 bell. The 92 tcu won't work and the 90 tcu won't plug into the 92 harness. Had to gave the solenoids rewired.
The output spline count is less on the renix era. So you'll have tcase issues.
http://www.jeepforum.com/forum/f177/92-xj-sadness-2075657/index2.html
uberxj92 is offline
