Auto trany - JeepForum.com
post #1 of 22 Old 03-12-2012, 03:13 PM Thread Starter
BigRedWilkey
Auto trany
I have a 1990 mj with the auto tranny. It won't shift and if been told that it is the shift control box. Has anyone else ever encountered this problem? And where is the shift control box???
BigRedWilkey is offline
post #2 of 22 Old 03-12-2012, 03:37 PM Thread Starter
BigRedWilkey
Just got told it was the transmission control module???
post #3 of 22 Old 03-12-2012, 04:01 PM
mj40
1989 MJ Comanche
mine was below the glove box like the one in the pic..
mj40 is offline
post #4 of 22 Old 03-12-2012, 06:00 PM Thread Starter
BigRedWilkey
Where can I get a new one ???
post #5 of 22 Old 03-13-2012, 07:29 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Wanna try something else first that's cheap and easy?
Right near the TCU, as shown in the above photo, is an inline fuseholder with a fuse in it. Normally wrapped in yellow tape. If that fuse is blown or corroded, that could be your whole problem.
cruiser54 is offline
post #6 of 22 Old 03-13-2012, 09:05 AM Thread Starter
BigRedWilkey
Already looked at the fuse you mentioned and it's good
post #7 of 22 Old 03-13-2012, 03:22 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Junkyard is the best place. They rarely fail. Get one from an 88 to 90.
Have you checked the connectors under the hood yet?
post #8 of 22 Old 03-13-2012, 05:54 PM Thread Starter
BigRedWilkey
Which connectors?
post #9 of 22 Old 03-13-2012, 06:01 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Near the trans dipstick tube there are 2 rather large squarish connectors. One is gray and the other black. Those two connectors are the information superhighway between the TCU, trans solenoids, speed sensor, and TPS. Unplug them, clean them out with electical contact cleaner, inspect the pins, add dielectric grease and plug them back together.
post #10 of 22 Old 03-14-2012, 07:45 AM Thread Starter
BigRedWilkey
Thanks I will try this when I get home and let you know!
post #11 of 22 Old 03-15-2012, 09:20 PM Thread Starter
BigRedWilkey
Checked the connection today. Very dirty so I cleaned them up and took it for a spin..... Sadly nothing. Any other suggestions?
post #12 of 22 Old 03-15-2012, 09:21 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
How many connectors did you clean? One or two?
post #13 of 22 Old 03-15-2012, 09:38 PM
Azzy
Search on here for AW4 Shift Pointers. it will tell you how to test your tps and see if you need to buy one. I know the latter ones run about 80 for used, and 200 for rebuilt.
Also check under your hood at the pdc and see if any of the fuses there are bad. Are your grounds good?
Im the guy who makes new gauges, check out our gallery at Teamadw.com
Azzy is offline
post #14 of 22 Old 03-22-2012, 08:13 AM Thread Starter
BigRedWilkey
I replaced the TCM last night and it fixed the problem! I had to go to 4 junk yards to find one but I finally did. Thanks to everyone for their time.
post #15 of 22 Old 03-22-2012, 08:23 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Glad to hear it. What year did you get the TCU out of?
