Another coolant loss thread - JeepForum.com
post #1 of 2 Old 08-30-2013, 12:46 PM Thread Starter
B_Hopps
I am on the hunt to locate the leak (think I actually found 2 under the radiator), plan to do a pressure test this weekend but this has more to do with a sound.
I've been hearing a sound that can only be described as the tone you get when you blow air across the top of a plastic bottle. It isn't constant, generally only when I get to 50-60 mph on the highway and then it's on and off.
Reading the Haynes manual it says that water pump shaft bearings may howl when they've failed.
How do I go about checking to see if this is the case?
B_Hopps is offline
post #2 of 2 Old 09-01-2013, 09:03 PM
Jeep_Fanatic
2012 MK Compass
check the water pump
-Rescue Green '12 Compass Sport 4x2 2.4L CVT daily driver
-New jeep coming soon
Jeep_Fanatic is offline
