another Comanche on/off the road - JeepForum.com
post #1 of 6 Old 04-11-2008, 09:01 PM Thread Starter
concretewake310
My 1989 4x4 longbed has bin sitting in my wifes dads yard for 4 years! After a starter, fuel pump, exhaust from manifold back, and a bunch of light bulbs. O yea cant forgit the trans filter. by the way what would the best trans fluid for my automatic transmission? Valvoline atf III is what I used with some lucas. The old stuff could of bin coffee. One other question the emass maint light is on what could be setting this off? it runs like new only 100,500 miles on it.
concretewake310 is offline
post #2 of 6 Old 04-12-2008, 07:59 AM
maddzz
1989 MJ Comanche
The emission maintenance light is probally from the oxygen sensor. They are programmed to go off at the scheduled maintenance interval (around 85,000 miles). They cant be reset you can either replace the timer or just disconnect it.
maddzz is offline
post #3 of 6 Old 04-12-2008, 08:56 PM
Pete M
1988 MJ Comanche
Yeah, that light is on a mechanical timer and goes off no matter what is going on with the truck. Most guys just disconnect it, but that depends on if you have inspections in your neck of the woods. Worse comes to worst you can likely get a replacement at the dealership.
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #4 of 6 Old 04-13-2008, 07:13 PM
Grand Fan 4eva
does this mean i can disconnect my MAINT REQRD light too? do i have to pull the dash or is there another way?
Thanks
'97 XJ ~5" / 33 trxus / RK 3-link / FOA 12" CO's
'91 MJ
'68 M715
'98 5.9 Limited
Grand Fan 4eva is offline
post #5 of 6 Old 04-14-2008, 07:15 AM
Pete M
1988 MJ Comanche
91+ have a real light and that likely means your O2 sensor is bad.
Jeep on!
--Pete
My email:
Pete M is offline
post #6 of 6 Old 04-19-2008, 07:08 PM Thread Starter
concretewake310
a new O2 sensor and taking out the light bulb so I could pass inspections. The o2 was rusted so the air could not pass threw it. 4 screws to get to the bulb very easy just put the trucks shifter all the way to the right the bulb pulls strait out.
On road/Off road tire pressure XJoutlaw XJ Cherokee Technical Forum 25 10-08-2009 01:18 PM
92 comanche JenLieber86 MJ Comanche Technical Forum 3 05-25-2007 11:04 AM
Does anyone need a Comanche Bed Cap XmetalxXxmikeJ MJ Comanche Technical Forum 0 05-07-2007 06:28 PM
Tire PSI on road/off road 89Cherokee4x4 XJ Cherokee Technical Forum 2 09-06-2006 11:24 PM
road racing comanche aladgie MJ Comanche Technical Forum 7 04-15-2006 01:21 AM
