Another belt Squeal - JeepForum.com
post #1 of 8 Old 09-12-2013, 09:21 PM Thread Starter
TrucksBootsNGun
1988 MJ Comanche
Another belt Squeal
Well I was tired of the belt squealing so i tightened and it split. got a new belt and put it on and the truck started squealing even worse. I had a spare idler laying around so I put it on because that seems to be the source of the noise and the truck just sits there and idles really nicely but as soon as you go above 1000 RPMs the squeal is there. I've adjusted the belt several times to no luck I even pulled off the idler and stuck some tranny/axle oil in it (no grease on hand) and that didn't really help. Anyone got any ideas?
On a side note any good tricks for knowing when the belt it too tight or too loose? After that belt split I'm just paranoid now.
TrucksBootsNGun is offline
post #2 of 8 Old 09-13-2013, 03:48 PM
carnuck
1984 J-Series Truck
Check the "bend" (aka deflection) when you push down between the 2 furthest points.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #3 of 8 Old 10-22-2013, 08:14 AM
CmpleteCherokee
1984 XJ Cherokee
depending on how old your belts were, they could have left material on the pulleys or even glazed them a bit. May be worth checking that as well
CmpleteCherokee is offline
post #4 of 8 Old 10-23-2013, 05:21 PM
dkroll
1988 MJ Comanche
Check to see if your harmonic balancer is okay also. If you have rubber sticking out of the front of it, you may want to see about replacing it. I have had belt travel enough to eat into my timing chain casing because of this. Can't be good on the belt either!
Doug
dkroll is offline
post #5 of 8 Old 10-24-2013, 06:17 AM
zackcj7
I second this. Very common problem on the MJs.
zackcj7 is offline
post #6 of 8 Old 10-27-2013, 06:41 PM
87MJTim
1987 MJ Comanche
+3
Ask me how I know.
Tim
87 Comanche, 4.0, AX15 (formerly BA10/5), D44
84 CJ7, 4.2, AX15 (Formerly T5)
87MJTim is offline
post #7 of 8 Old 10-28-2013, 12:29 PM Thread Starter
TrucksBootsNGun
1988 MJ Comanche
Update: so i have found that this design is a PITA to work on because if its a little too tight: squeal. Little too loose: squeal. Problem I'm having now is i can only get 3 tries or so before the belt warms up and stretches and no longer squeals. Since it goes away like 5-7 mins after starting the truck I am happy.
Thanks for all the help guys.
post #8 of 8 Old 10-29-2013, 05:34 AM
dkroll
1988 MJ Comanche
I have also sprayed belt dressing on the belt, it helps also.
Doug
dkroll is offline
