Air bagging Comanche for LOW! Can it be done? - JeepForum.com
post #1 of 19 Old 08-01-2013, 05:31 PM Thread Starter
Burntoast87
I just picked up my first jeep Comanche so stoked.
Was just wondering if air bagging a jeep is possible ?
Never owned a truck only Vw's. so not to smart with trucks
Burntoast87 is offline
post #2 of 19 Old 08-02-2013, 08:07 PM Thread Starter
Burntoast87
Help
post #3 of 19 Old 08-03-2013, 07:21 AM
ibjeepin95
Of course it's possible. Do your research and get to work.
ibjeepin95 is offline
post #4 of 19 Old 08-08-2013, 10:53 AM Thread Starter
Burntoast87
Why can't anyone just help me ? I been searching n can't find anything
post #5 of 19 Old 08-08-2013, 11:06 AM
mschi772
1997 XJ Cherokee
Be patient. The MJ forum isn't the most bustling page on the web. It might be a few days before someone with something to say sees your post and responds.
Build Thread -- http://www.jeepforum.com/forum/f177/whats-chrokeese-build-thread-2525690/
mschi772 is offline
post #6 of 19 Old 08-08-2013, 01:03 PM Thread Starter
Burntoast87
Thx buddy
post #7 of 19 Old 08-10-2013, 06:38 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Maybe because nobody has done it on an MJ?
Have you ever airbagged a vehicle?
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #8 of 19 Old 08-11-2013, 12:37 AM
Michaelgoesrawr
Like, to make a mini truck out of it? The horror.
Damn near anything can be done if you try hard enough. So you just need to figure out how much work, money, and time into it and go for it.
Michaelgoesrawr is offline
post #9 of 19 Old 08-11-2013, 12:44 AM
rebelbowtie
If you have ever air bagged a vehicle before then you should be able to figure it out.
rebelbowtie is offline
post #10 of 19 Old 08-11-2013, 01:03 AM
Sasquatch4x4
It Wouldn't be too hard, it'd be a lot easier with two wheel drive so you dont have to worry about the front axle and clearing everything once you lower the truck. the rear would be easy to lower you'd just have to cut into the bed.
Check Out My YJ Build and Give me Advice!! : http://www.jeepforum.com/forum/f22/blue-95-yj-built-college-kid-w-part-time-job-1428767/
Sasquatch4x4 is offline
post #11 of 19 Old 08-12-2013, 10:23 AM Thread Starter
Burntoast87
My truck is a rear wheel drive but I'm just lost at the leaf spring part.
To the other guys asking if I ever bagged a car or truck. That's a nooooo
post #12 of 19 Old 08-13-2013, 03:12 PM
Ratrod
I googled air bagged jeep truck and a Andy's Auto Sport has them for a Commanche.
1996 RHD XJ
Ratrod is offline
post #13 of 19 Old 08-22-2013, 09:42 PM
NYTrailrider
1988 MJ Comanche
Wrong forum
88 Comanche AX15/NP231 swap. Zone 4.5" lift Future-Dana 44s, lockers, 36" tires, 4BT swap
NYTrailrider is offline
post #14 of 19 Old 09-16-2013, 08:10 PM
87bagdmanche
87bagdmanche is offline
post #15 of 19 Old 09-16-2013, 08:12 PM
87bagdmanche
built a frame for it out of 2x3 and did a toyota front clip so it has control arms up from lays body on 18's had to heavily modify the upper and lower control arms and had to triangulate the lower arms so i could get rid of the radious arms and did toyota drop spindles with isuzu hubs and rotors so i made it 6 lug and put a isuzu rear in it
