99 Dash install in 92 comanche - JeepForum.com
post #1 of 7 Old 09-17-2012, 10:51 PM Thread Starter
martin809
I just picked up a 1992 Jeep Comanche.
I also pulled a 99 dash out of a cherokee. I took the complete dash steering wheel and the wiring harness.
My question is do I have to use the harness. If so how much. I did not grab everything, but if I need to go back I can.
I know if I bought a doner and sat it next to it I would just move everthing over.
Right now I just want to complete the dash. The motor is good and I don't need to go OBII.
Yes I will change doors fender and grill eventually 97+
1992 Jeep Comanche
5 speed
4.0
martin809 is offline
post #2 of 7 Old 09-17-2012, 11:02 PM Thread Starter
martin809
I have tried to join the Comanche Club but can't Just FYI
post #3 of 7 Old 09-22-2012, 04:05 AM
LimeLJ
LimeLJ's Avatar
Your CC account should be working. I just checked!
To do the swap you will need the complete under hood engine setup and harness. The gauge cluster is all digital and will only work with a 1997-1999 computer and wiring setup.
Basically, you have a big project ahead of you. Good luck!
LimeLJ is offline
post #4 of 7 Old 09-26-2012, 03:56 PM
rymanrph
1997 MJ Comanche
There is a lot more to it than just swapping the dash. The firewall has to be modified to accept the newer wiring harness, a relocated steering column and a few other small things. Unless you want to try and make the old cluster setup work in the new dash (not sure how you would even attempt that), you're better off swapping everything to the newer '99 stuff. You can see some details in my build and there are several more here and over at the Comanche Club forums that go into detail as to what is required. The swap isn't difficult, but it will take some time. Don't plan on it being a one or two weekend affair.
rymanrph is offline
post #5 of 7 Old 09-26-2012, 08:46 PM Thread Starter
martin809
Thanks for the responses. I knew there was alot involved and I did'nt mind the work. I just don't have the computer or and of the OBDII stuff involved. Maybe someday I will find a complete donor and make it happen.
I was also able to get into the Comanche Club Forum....Lot of good info there!!
post #6 of 7 Old 11-14-2012, 08:57 PM
southpaw26
I may have the complete donor you desire.
southpaw26 is offline
post #7 of 7 Old 11-14-2012, 11:00 PM Thread Starter
martin809
PM me with what you have, I am in the East Brainerd area. I can go anywhere just about any time to check out what you have.
1 ton install on Comanche nortron MJ Comanche Technical Forum 9 11-14-2012 11:15 PM
'89 Comanche Brake light on Dash stays on? MRCLIVE MJ Comanche Technical Forum 7 04-25-2010 12:36 PM
looking for thread about CB install in dash 97+ XJRustler XJ Cherokee Technical Forum 6 02-12-2009 04:12 PM
Center dash vent CB install thread!! XJ_Hunter XJ Cherokee Technical Forum 25 06-02-2008 10:05 AM
7" lcd in dash monitor install? ajspellm XJ Cherokee Technical Forum 14 06-13-2005 06:24 PM
