92 Commanche 4x4 manual trans - JeepForum.com
post #1 of 4 Old 07-16-2013, 01:23 PM Thread Starter
rookie247
Hello all, I have a friend that owns this vehicle and she told me her clutch was out and needed a new one. So a friend and I replaced the clutch and slave cylinder.. we got all the air out of the lines and we have a very good pedal. It will shift through all the gears with the engine off but when you start the truck and push in the clutch it will not shift into any gear. The pressure plate was installed in the correct way because we paid close attention to that and the fluid was new and bled properly. We have a good pedal. After we finished the owner told us that that is what it was doing prior to replacing the clutch. Any suggestions would be much appreciated.
rookie247 is offline
post #2 of 4 Old 07-19-2013, 06:34 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The clutch master cylinder is probably on it's way out also.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 4 Old 07-21-2013, 04:13 AM Thread Starter
rookie247
Replaced the clutch master cylinder and the clutch still won't allow me to shift. I checked the gear oil and it was very low. I added gear oil but still won't shift.
post #4 of 4 Old 07-31-2013, 02:24 PM Thread Starter
rookie247
Well, I thought I would let the forum know the outcome of my problem. It appears that the synchronized gears in the transmission are seized. I hope I said that correctly. We are currently looking for a new/used transmission, oh boy! !
Thanks for the suggestions, I do appreciate it.
