92 Comanche tranny gasket and filter change - JeepForum.com
post #1 of 3 Old 05-04-2008, 08:59 PM Thread Starter
last2letUdwn
I am thinking about changing the filter and tranny pan gasket on a 92 Comanche. I am fairly mechanically inclined. Is there anything tricks I need to know before doing this. How long should this job take?
Thanks for the input
last2letUdwn is offline
post #2 of 3 Old 05-07-2008, 07:27 AM
romeo_zooloo
1989 MJ Comanche
I am fairly unmechanical and managed to do it. Although, I think I inadvertently used a permanent form of Permagasket to reinstall the pan. Filter and gasket was less than $20, drained out about 6 to 6.5 qts of the fluid located a drain plug towards the rear of the pan. Be careful of small hoses and things inside when cleaning off gasket and sealant from bottom of trans housing. I don't know if there is a torque converter drain. There were two magnets in the pan with some gray powder and a few larger metal flakes. Should I be concerned? I haven't gone very far and fluid is already going pink/gray. Seems to be shifting fine.
Good Luck RZ
romeo_zooloo is offline
post #3 of 3 Old 05-07-2008, 09:56 PM
Pete M
1988 MJ Comanche
Always be prepared for a big mess when dropping the pan of an automatic trans. And wear safety goggles and ear plugs when under the rig.
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
Comanche leaking valve cover gasket JacksYJ MJ Comanche Technical Forum 1 05-11-2008 09:31 PM
how hard to replace tranny oil pan gasket, valve cover gasket, and oil filter o-rings iwishihad1 XJ Cherokee Technical Forum 4 04-11-2007 06:30 PM
When to change tranny filter?? x550x XJ Cherokee Technical Forum 33 06-02-2006 12:28 AM
auto tranny oil and filter change problem lachleaves XJ Cherokee Technical Forum 5 08-03-2005 10:13 AM
When to change to Tranny fluid/filter? jeeptime XJ Cherokee Technical Forum 9 09-24-2004 08:32 AM
