91 Manche - JeepForum.com
post #1 of 7 Old 12-14-2006, 07:28 PM Thread Starter
Rwork
91 Manche
I recently was able to purchase a 91 MJ Eliminator with 138k on a 4.OL. Cab is pretty decent bed needs some work. It runs excellent, however I am looking for help with one problem. I definitely need some new shocks/coils. It is rather bouncy when I hit a ruff road. I was thing of replacing rear leafs/front coils and shocks. I am not necessarily looking for a lift although I would not mind a small one. What would be the best and most cost effective way to go?
Rwork is offline
post #2 of 7 Old 12-15-2006, 04:39 AM
Comanche5L
well you could get coils from a v8 grand cherokee, and maybe a 1" spacer, get the rear leafs re-arched, and add 4 longer shocks should give you a decent looking stance and clear 31's
make sure they are from a v8 ZJ though, any pics?
'88 Comanche, '01 front clip, Mustang 5L, T-5 & Tonns of unnecessary noise
'91 Comanche, '01 front clip, I6 H.O, RE 3.5" Superflex
'91 CJ'd Sahara 4L
Comanche5L is offline
post #3 of 7 Old 12-15-2006, 06:43 AM
97_4popper
1990 MJ Comanche
I just so happen to have a brand new small lift (3") for sale in the classifieds. . .
http://www.jeepforum.com/forum/showthread.php?t=322663
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #4 of 7 Old 12-15-2006, 07:06 PM
Pete M
1988 MJ Comanche
Your springs are most likely just fine and your shocks are toast. Get some decent gas charged shocks and you should be good to go.
Jeep on!
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #5 of 7 Old 12-16-2006, 09:11 AM Thread Starter
Rwork
Thanks for the info. As far as the lift, do you need SYE or to drop transfer case? Just wondering. I will post some pics as soon as I can.
Rwork is offline
post #6 of 7 Old 12-16-2006, 10:27 AM
JeepDoggyDog
Jeep Obsessive Compulsive
JeepDoggyDog's Avatar
1991 MJ Comanche
I have a 3 inch Rancho on mine and didn't need the SYE. If I had it to do over again OME HD 3 inch front springs and Rusty's 4 inch rear Leafs. I have 31's and the fronts rub a bit.
1998 Sahara Auto with stuff(Sold 03/2006)
1997 ZJ Grand Cherokee (Sold 06/2002)
1991 Comanche Eliminator
JC bored out throttle body, Rancho 3 inch lift, rebuilt AX-15,.Teralow 4:1, 3.73 gears, and 31 inch Cooper STT
2000 Cherokee intake ready to install
JeepDoggyDog is offline
post #7 of 7 Old 12-16-2006, 01:18 PM
Pete M
1988 MJ Comanche
No. Cherokees do, but MJs have a foot more wheelbase and can go ~5" with the stock driveshaft. Be aware that U-joints do not like to have their operating angles changed and it is advised to change those if you add lift.
Jeep on!
--Pete
My email:
Pete M is offline
Got my Manche this AM SuperWade2 MJ Comanche Technical Forum 15 12-22-2007 08:47 PM
New manche owner camjeep3 MJ Comanche Technical Forum 5 09-25-2007 04:21 PM
New '88 manche! SoloCamo MJ Comanche Technical Forum 7 10-31-2006 01:05 PM
My Manche MISFIT MJ Comanche Technical Forum 15 07-01-2006 01:53 AM
Super Manche CanadianJeep86 MJ Comanche Technical Forum 11 05-24-2006 12:57 AM
