90 comanche starting problem - JeepForum.com
post #1 of 3 Old 04-06-2008, 03:59 PM Thread Starter
tatered1
Ok this is a weird one the engine will only stay running if the key is held in the start position if you let go of the key it dies.
the ignition switch has been replaced and the ignition module tested and checked ok
anyone had this problem before?
tatered1 is offline
post #2 of 3 Old 04-06-2008, 06:08 PM
Pete M
1988 MJ Comanche
Have you tried bypassing the ceramic resistor on the fender? When cranking the computer puts direct power to the fuel pump, but after that it sends power through the resistor (whose purpose is to cut the voltage a bit and quiet the pump down). Try connecting the wires directly together and see what happens. (it won't harm anything, 87s didn't even have them)
Jeep on!
--Pete
P.S. you are "activated" at the MJ club, even if you didn't get the automated email.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #3 of 3 Old 04-09-2008, 10:42 AM
maddzz
1989 MJ Comanche
I had the same exact problem. Its not the ballist resistor. It is a wire behind the battery next to the fusible link. Im not sure which wire because I finally brought it to a shop that specializes in aut electrical.
maddzz is offline
1987 Jeep Comanche Starting Issues billyshred MJ Comanche Technical Forum 6 11-10-2011 01:07 PM
Jeep comanche wont start without starting fluid YUKONJACK MJ Comanche Technical Forum 4 09-03-2008 11:54 AM
88 comanche starting prob. PSCjosh MJ Comanche Technical Forum 9 12-24-2006 08:32 AM
comanche power problem (HELP) franks67gto MJ Comanche Technical Forum 6 06-25-2006 09:35 PM
Comanche Problem kyleboy7 XJ Cherokee Technical Forum 5 03-19-2004 07:45 AM
