Quantcast '90 4.0 Cranks, won't fire! - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > '90 4.0 Cranks, won't fire!
Old 11-09-2009, 07:52 AM   #1
jimmyt01
1990 MJ Comanche
Help! Couple of nights ago, pulled in at home, running fine, shut it off. Went to start next morning, just cranked and cranked, would not fire or start. Checked spark with an in-line spark-checker, no spark! Figured bad coil, replace it, still no go. Re-checked spark, again nothing. Where do I go from here? The schematic shows what appears to be two 60A fuses in the "Power Control Center" (Fuse Block?), do they provide the circuit to the ignition control module, and might it be the module itself? Do they go bad like that out of the blue with no warning? Any suggestions would sure be welcome, I'm using my Dad's Ram and blowing my gas allowance!
jimmyt01 is offline   Reply With Quote
Old 11-09-2009, 10:09 AM   #2
Pete M
1988 MJ Comanche
look into the CPS. I think the 60A fuses are in the 91+ schematic.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email: petermontie@hotmail.com
ComancheClub.com/forums
Pete M is offline   Reply With Quote
Old 11-09-2009, 10:09 AM   #3
vaquaro
1990 MJ Comanche
Had exactly the same problem a few weeks ago ....Replaced the ICM and away she went
90 MJ SporTruck 2.5 AX4 2WD SWB
vaquaro is offline   Reply With Quote
Old 11-09-2009, 10:37 AM   #4
jimmyt01
1990 MJ Comanche
Thanks, guys, I was pondering both those items, I'll try tonight and see what I come up with. Have a great day.
Old 11-09-2009, 01:46 PM   #5
ffemtevt
1988 MJ Comanche
I would go with the crank sensor. Was a common problem for a longtime.
ffemtevt is offline   Reply With Quote
Old 11-13-2009, 10:45 AM   #6
jimmyt01
1990 MJ Comanche
I initially replaced the coil, still had no spark, took out the ICM and had it tested, showed bad. Picked up a salvage unit, put it in, still no spark, took it out and had it tested, tested good, so I picked up a CPS, will be putting it in tomorrow, will let ya's know if that does the trick.
Glock Forum
