'89 Comanche Part-Time light stuck on - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > '89 Comanche Part-Time light stuck on
RCV Heavy Duty Axle Shafts Now Shipping at Baseline4x4.comBUMPERS by Rough Country! SOLD at ROCKRIDGE 4WD!! AWESOME New Wurton LED Pod Lights Brought To JF By Rockridge 4WD!
Unread 10-09-2006, 05:09 PM   #1
rebelmachine390
Hey Guys,
2 quick questions for you:
1.) As soon as I start this Jeep and get vacuum built up, the part-time light comes on and stays on. If I floor it, or disconnect vacuum from the underhood 4WD switch, it turns off. The underhood switch ALWAYS has engine vacuum at it, in 2WD or 4WD. Is it supposed to? When I first started working on it, the front axle disconnect was disconnected. As soon as I reconnected it, the light was on. The 4WD works normal, in 2WD, 4WD, and 4LO. Any ideas?
2.) The transfer case bezel shows a 4 wheel HI-LOCK, and a 4 wheel LO-LOCK. What is that? I can't find anyone who knows. It is just a standard Command-Trac T-case, is there something to these locks? Thanks!
rebelmachine390 is offline   Reply With Quote
