Quantcast 88' MJ 2.5L 4spd 2wd to 4wd qeustions !?!?!? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > 88' MJ 2.5L 4spd 2wd to 4wd qeustions !?!?!?
Truck-Lite's New LED Headlamp SeriesGR8TOPS Introduces the Exogate HD Tire CarrierRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 11-18-2009, 04:29 PM   #1
AMCSportTruck
1988 MJ Comanche
I been kicking around the idea of swapping my MJ from a 2wd to a 4wd . . .
Truck is currently powered by the 2.5L I-4/4spd combo, but will be upgraded to V-8/5spd combo. . .
I read it's best to have a second Rig thats got the axles n T-case ect.
The local salvage yard has 2 dozen 4x4 Cherokee's but no MJ trucks.
Can this swap be done with Cherokee parts ?
Is it worth while ?
Mike
AMCSportTruck is offline   Reply With Quote
Old 11-18-2009, 08:53 PM   #2
89eliminator
1989 MJ Comanche
cherokee is the same thing. you will need a 4x4 MJ rear driveshaft though, but by the sounds of it, that wont work either.
WI4x4.com
89eliminator is offline   Reply With Quote
Old 11-18-2009, 09:04 PM   #3
AMCSportTruck
1988 MJ Comanche
Why won't the rear driveshaft work ?
As in it'll work with the I-4 ?
But
Not the V-8 ?
Mike
Old 11-18-2009, 09:05 PM   #4
89eliminator
1989 MJ Comanche
correct. it may work with a V-8/5spd combo, but i wont guarantee that.
WI4x4.com
Old 11-18-2009, 09:10 PM   #5
AMCSportTruck
1988 MJ Comanche
Well I figured there would be a swap over then later a rearrangement once it was V8/5spd time.
Mike
Old 11-20-2009, 09:09 AM   #6
AMCSportTruck
1988 MJ Comanche
2 part swap 2wd to 4wd then later I-4 to V-8 . . .
Ok now what Axles should i be looking for ?
there any way to tell them apart ?
as you all know the I-4 only makes 117hp n 135tq, But the AMC 290 V-8 produces 225hp n 300tq, and when with running a 5spd manual trans along with it.
i'll need some decent Axles. . .
set 1. Make the MJ a 4WD.
recoup from that spending then onto step 2.
step2. Repower truck with AMC 290 V-8 Engine.
I under stand the I-4/4spd to V-8/5spd may require custom drive shafts and possibly a different transfer case but i was hopping to only have to do 1 axle swap
Mike
Old 11-20-2009, 05:25 PM   #7
89eliminator
1989 MJ Comanche
front axle is fine, get a D44, AMC 20, or Ford 8.8 for the rear.
WI4x4.com
Old 11-20-2009, 08:16 PM   #8
AMCSportTruck
1988 MJ Comanche
What axle do they use for the fronts ?
Sorry new to jeeps...
Mike
Old 11-20-2009, 09:06 PM   #9
89eliminator
1989 MJ Comanche
HP Dana 30
just saw your in WI too. im about 90 minutes from ya
WI4x4.com
Old 11-20-2009, 09:13 PM   #10
AMCSportTruck
1988 MJ Comanche
Cool stuff Good to meet ya...
So the D30 will handle the V8 but the D35 won't correct ?
Mike
Old 11-20-2009, 09:33 PM   #11
89eliminator
1989 MJ Comanche
D35s can barely handle (and sometimes they cant) stock Jeeps. if you upgrade the shafts in the 30, you should be good. Your "only" putting in a 290 so the 30 should be plenty strong.
WI4x4.com
Old 11-20-2009, 09:50 PM   #12
AMCSportTruck
1988 MJ Comanche
Don't under estimate that lil'290 out it that little beast turns out 225hp n 300tq.
Its a rather stout engine tho its a premium fuel unit as it has 10.2:1 compression.
Its all factory it was design for moving around 3800-4200lb cars 2.87 - 3.15 Gears 26-28" tall tires even.
AMC290 2bbl: 200hp n 260tq.
AMC290 4bbl: 225hp n 300tq.
Not to bad when you figure a 350TBI makes 210hp n 300tq. . .
Mike
Glock Forum
