88 comanche clutch - JeepForum.com
post #1 of 3 Old 09-02-2012, 09:26 PM Thread Starter
west4967
1988 MJ Comanche
88 comanche clutch
i recently replaced the engine in my 88 comanche with another rebuilt 4.0. in the prosses i put a new clutch kit in it but now i cant get the clutch to work blew out two slave cylinders befor i tried shiming between the fly wheel and pressuer plate ive now shimed it 0.15 and the sleve cylinder dosnt blow out but stil cant get the clutch to work. i think i have the wrong pressuer plate but itsthe only one the auto parts stores show for it and i dont have the old one to compare them. any advice or thoughts apreceated
west4967 is offline
post #2 of 3 Old 09-19-2012, 09:13 AM
hillbilly51
1988 MJ Comanche
Did you put the clutch disc in backwards?
You wouldn't be the first if you did.
The hub on the clutch disc goes into the pressure plate.
hope this helps
steve
hillbilly51 is offline
post #3 of 3 Old 09-21-2012, 08:09 AM Thread Starter
west4967
1988 MJ Comanche
hope this helps
steve
no i didnt it was just the wrong pressure plate i had to order one online. for some reason none of the auto parts stores around here show a clutch for that puguson transmission.got it going now.thanks to ebay
west4967 is offline
Jeep Comanche clutch problems starkizer XJ Cherokee Technical Forum 0 11-04-2010 07:44 PM
84 Comanche Clutch Slave cyl leak guruofguns MJ Comanche Technical Forum 5 11-12-2009 11:20 AM
Comanche clutch: interchangable? gavin8or MJ Comanche Technical Forum 9 02-09-2007 04:08 PM
89 Comanche Hyd Clutch DYNOMAN MJ Comanche Technical Forum 1 11-21-2006 05:07 AM
88 Comanche Intermittant Clutch Prob MAXXFAST MJ Comanche Technical Forum 3 10-04-2006 10:46 PM
