87 Comanche motor cranks but no spark - JeepForum.com
post #1 of 7 Old 08-04-2012, 05:31 AM Thread Starter
87manche17
1987 MJ Comanche
I've have just put a new motor in a Comanche equipped with the reniex system. It was running fine until I swap the motor now it will crank but I'm getting absolutely no spark. I've changed my distributor, wires, and my CPS and still no luck. I've had a friend check my coil for resistance and he said it was fine so where do I go from here?
87manche17 is offline
post #2 of 7 Old 08-04-2012, 06:14 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Did you get the ground wires hooked back up at the dipstick tube stud?
cruiser54 is offline
post #3 of 7 Old 08-04-2012, 10:53 AM Thread Starter
87manche17
1987 MJ Comanche
yeah I put that one back as well as the one on the firewall.
post #4 of 7 Old 08-04-2012, 02:02 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
One? There's at least 3 at the dipstick tube stud.
post #5 of 7 Old 08-20-2012, 09:27 PM
greaseslapper
1987 MJ Comanche
it will still start without the grounds on the dipstick, or else my truck ceases to die i ran mine for a week till i noticed they wernt hooked up. is the fireing order right? are the coils bad?
2.5 four wheel drive.
greaseslapper is offline
post #6 of 7 Old 08-20-2012, 09:29 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Well, aren't we the newbie with all the answers...........
post #7 of 7 Old 08-22-2012, 01:55 PM
greaseslapper
1987 MJ Comanche
Aww, Thanks.
97 xj 4.0 Cranks No spark new cps nd4spd4axj XJ Cherokee Technical Forum 30 06-03-2014 10:33 AM
need help, motor cranks, have no spark 87manche17 XJ Cherokee Technical Forum 6 08-03-2012 03:16 PM
cranks, but no spark dirtdad XJ Cherokee Technical Forum 2 07-29-2011 04:55 AM
4.0 cranks but no spark ZeroLag XJ Cherokee Technical Forum 6 08-24-2009 12:18 PM
87 Comanche cranks but wont turn over Ethox MJ Comanche Technical Forum 8 03-30-2009 10:06 PM
