87 comanche amc to chrysler 4.0 swap - JeepForum.com
post #1 of 19 Old 02-01-2013, 08:32 PM Thread Starter
Thejim42
1988 MJ Comanche
I have a 1987 jeep comanche pioneer that is in amazing shape. It originally had a 4.0 straight 6 with a 5 speed trans 2wd short bed. My uncle gave me this truck as a project but it has no engine. What would it take to put a chrysler 4.0 in place of the original renix 4.0. anyone have any information or has anyone done this?
Thejim42 is offline
post #2 of 19 Old 02-02-2013, 08:10 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
By Chrysler I think you're referring to 91 and later HO?
Here's how. Easy.
Cruiser’s HO into Renix Swap
This swap is easier than some will lead you to believe, generally those who have never done it. Those of us who have done it, like myself, will share with you the things that need to be done for a successful swap. Just think of it as swapping in a long block.
The HO and Renix have some differences but none that can’t be overcome very easily.
Any HO engine from an XJ or ZJ through 1998 can be used. One running change was that the rear of the head was no longer drilled and tapped for the temperature gauge sender beginning in the 96 model year. The sender can be relocated to the threaded hole in the thermostat housing taken from the HO engine. You’ll have to extend the wire to that location. Some brave souls even drill and tap the HO head for the sender.
You will be using the intake and exhaust manifolds from your Renix, along with all your sensors and wiring. Since the intake ports of the HO are slightly different, you use the Renix gasket. Exhaust ports are identical.
You will need to use your Renix distributor as it is different than the HO because they use different fuel management systems. The flywheel or flexplate from the Renix must be used so your CPS gets the correct signals. The valve cover from the Renix allows you to keep your CCV system intact and requires no modifications.
The HO block will have a plug in the coolant galley on the driver’s side of the block, closest to the front, which needs to be removed so your Coolant Temp Sensor can be installed in it’s place just as it is on the Renix. It requires a 5/16” square drive or a modified 3/8” drive that has been ground down to fit. Do this before installing the engine.
As for the knock sensor, which is located just above the oil pan on the driver’s side of the engine about mid way, all the blocks I’ve seen are threaded for it. If not, I’ve heard they may be drilled but not tapped. Tap the hole if that’s the case.
Revised 07/24/2012
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #3 of 19 Old 02-03-2013, 05:55 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
This may help you, too:
XJ Cherokee and ZJ Grand Cherokee 4.0L engine blocks interchange.
2000+ TJ Wrangler and WJ Grand Cherokee 4.0L engine blocks interchange.
XJ/ZJ blocks and 2000+ TJ/WJ blocks do not interchange without significant modifications. (1991 to 1995 YJ and 1997-1999 4.0L TJ Wrangler blocks will interchange in XJ/ZJ and visa-versa).
TJ/WJ 4.0L Engine blocks underwent clean sheet design changes effective in the 1999 WJ Grand and 2000 TJ Wrangler. These blocks are not interchangeable with XJ/ZJ engine blocks. The reason is motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ.
XJ: "Regular" (not Grand) Cherokees 84-01
ZJ: Grand Cherokee 93-98 (Gen1)
WJ: Grand Cherokee 99-04 (Gen2)
YJ: Wrangler 87-95 (Gen1)
TJ: Wrangler 97-06 (Gen2)
post #4 of 19 Old 03-03-2013, 11:03 AM Thread Starter
Thejim42
1988 MJ Comanche
Could i put the renix in place of the HO in a 92 wrangler?
Thejim42 is offline
post #5 of 19 Old 03-03-2013, 11:44 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Yes. As long as you use all the stuff that is on your Wrangler longblock. Use the intake/exhaust gasket for the Wrangler engine.
post #6 of 19 Old 03-03-2013, 11:53 AM Thread Starter
Thejim42
1988 MJ Comanche
Jut the intake and exhaust?
Thejim42 is offline
post #7 of 19 Old 03-03-2013, 12:07 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
No. You have to swap the distributor, flywheel, intake and exhaust manifolds,valve cover etc. also. I was just specifying and clarifying which gasket to use when going from HO to Renix.
post #8 of 19 Old 03-03-2013, 12:13 PM Thread Starter
Thejim42
1988 MJ Comanche
Ok...sounds like a headache
Thejim42 is offline
post #9 of 19 Old 03-03-2013, 12:25 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Really? You'd have to swap all that stuff over if you got another Wrangler engine. Is it possible that either one is above your skill level?
post #10 of 19 Old 03-03-2013, 12:34 PM Thread Starter
Thejim42
1988 MJ Comanche
If i got the same year wrangler engine for the wrangler why would i need to swap everything?
Thejim42 is offline
post #11 of 19 Old 03-03-2013, 12:35 PM Thread Starter
Thejim42
1988 MJ Comanche
I have never messed with anything where i would need to remove timing components
Thejim42 is offline
post #12 of 19 Old 03-03-2013, 12:46 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Well, it seems to me you've got this all figured out then.
post #13 of 19 Old 03-03-2013, 12:53 PM Thread Starter
Thejim42
1988 MJ Comanche
Its just easier to get ahold of an H.O than a renix
Thejim42 is offline
post #14 of 19 Old 03-03-2013, 12:57 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Hope you're a wiz at wiring..........
post #15 of 19 Old 03-03-2013, 01:05 PM Thread Starter
Thejim42
1988 MJ Comanche
How much of a headache is it to change a wiring harness?
Thejim42 is offline
comanche
