87 comanche 4x4 4.0 5spd - Page 4 - JeepForum.com
post #46 of 50 Old 02-19-2013, 07:26 PM
97_4popper
1990 MJ Comanche
If heater core is bad, it would probably be leaking.
Check your thermostat. that may be why it doesn't blow warm.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #47 of 50 Old 02-20-2013, 08:20 AM
Mishimoto
Vendor
Mishimoto's Avatar
+1, unless the core is clogged and restricting coolant flow.
Mishimoto is offline
post #48 of 50 Old 02-21-2013, 09:35 AM Thread Starter
donutman07
1987 MJ Comanche
my friend and i somewhat cleaned out the heater core by flushing out a bunch of what looked to be rust and gunk, we flushed it out with water, and when he drove it over to my house he said that there was a little bit of heat comming out of it now.
donutman07 is offline
post #49 of 50 Old 02-21-2013, 05:58 PM Thread Starter
donutman07
1987 MJ Comanche
i took irt fora little drive out back behind the house and had to use the 4wd and now the 4wd light is staying on does anybody have any ideas on what i should check? any help would be much appreciated
post #50 of 50 Old 02-22-2013, 11:48 PM
carnuck
1984 J-Series Truck
Probably bad hose or the switch on the trans is stuck.
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
5spd help crockett07 XJ Cherokee Technical Forum 7 07-16-2012 03:49 PM
AMC-290 V8 + AX-15 5spd + MJ AMC-20 ! AMCSportTruck MJ Comanche Technical Forum 35 05-05-2011 03:16 PM
How good is a 4x4 5spd shortbed Comanche as a starting point? jfman MJ Comanche Technical Forum 39 01-30-2011 01:16 AM
question about comanche 5spd tranny dontknow MJ Comanche Technical Forum 1 05-17-2009 01:59 PM
NSS on a 5spd? Marine_Psycho XJ Cherokee Technical Forum 6 12-22-2006 11:08 AM
