87 comanche 4x4 4.0 5spd - Page 3 - JeepForum.com
post #31 of 50 Old 11-30-2012, 07:56 AM
Mishimoto
Vendor
Mishimoto's Avatar
Originally Posted by 97_4popper View Post
Should be able to at any hardware store that makes keys.
If not, check online. I've seen them on ebay.
^This. Places like ACE hardware, Lowes and some Walmarts.
Mishimoto is offline
post #32 of 50 Old 12-03-2012, 03:37 PM Thread Starter
donutman07
1987 MJ Comanche
i was wondering what guage clusters (what years and what models) would fit in the jeep comanche so i can get rid of that big fuel guage and have a tach. and if anybody had one that would be great i only need the tach. any help would be much appreciated.
donutman07 is offline
post #33 of 50 Old 12-03-2012, 05:03 PM
automan2164
1986 MJ Comanche
Go to Comanche club. You will get more info and help over there.
Rob
'86 MJ 2.1L 4x4 MT LWB - Factory Diesel
'87 MJ 4.0L 4x2 AT LWB - Metric Ton
'97 XJ 4.0L 4x4 AT Country
automan2164 is offline
post #34 of 50 Old 12-03-2012, 05:09 PM
Tylerzap
I paid 200 for my MJ and it has NO drivers floor, barely idles, and is beat to hell. You sir are very lucky.
My 98 XJ "Zap" Build Thread
1988 Jeep Comanche 4x4 Longbed - POS
Tylerzap is offline
post #35 of 50 Old 12-03-2012, 05:19 PM
97_4popper
1990 MJ Comanche
Rob
Cherokee dashes fit. That's where I got mine from. Same as yours.
Check my build thread below.
And go over to comancheclub.com.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #36 of 50 Old 12-13-2012, 01:49 PM Thread Starter
donutman07
1987 MJ Comanche
does anybody know where i can find a transmission monut for a ba/10 that i have in my 87 comanche with the 4.0?
post #37 of 50 Old 12-13-2012, 01:56 PM Thread Starter
donutman07
1987 MJ Comanche
and i also was wondering do i need a standard rotating pump or do i need to get one that rotates counter-clockwise?
post #38 of 50 Old 12-15-2012, 06:42 PM
ftpiercecracker
1990 MJ Comanche
Dont waste a single dime on that ba-10, find an ax-15 and save yourself the hassel ,
Order a water pump or pull one off of another jeep (make sure its the right year), i've never actually noticed which way it rotates, but i wouldnt give it another thought. I have never heard of anyone ever having a reverse directional water pump, at least on a 4.0.
ftpiercecracker is offline
post #39 of 50 Old 12-17-2012, 07:10 PM Thread Starter
donutman07
1987 MJ Comanche
i need to replace the u joints all the way around in my comanche i was just wondering how many i need to buy and what ones i need to buy for the certain part of the truck?
post #40 of 50 Old 12-22-2012, 07:13 PM
JeepComanche89
1989 MJ Comanche
3 for the front, 2 for the rear. Spicers came stock in comanches and are a good replacement.
JeepComanche89 is offline
post #41 of 50 Old 12-23-2012, 11:23 PM
ftpiercecracker
1990 MJ Comanche
this is what i figured as well but what are you supposed to do with that thing on the front driveshaft where it meets the T-case??? I'm not even sure what its called.
post #42 of 50 Old 12-24-2012, 02:19 PM
JeepComanche89
1989 MJ Comanche
Im not sure of the terminology either, but i did not have to replace mine, but if its worn it will need to be replaced. I didnt have the time to try to figure out how replace the u joints on that front shaft, so I sent it to the shop. I had to get my rear shaft cut and balanced, so i figured why not.
post #43 of 50 Old 12-25-2012, 04:55 PM Thread Starter
donutman07
1987 MJ Comanche
does anybody know what kind of oil and what weight of oil i should use for the ba/10 i have napa brand 80w90 oil but i have seen quite a few timesto use some weight of motor oil?
what works best for the ba/10 from those of you who have the ba/10 it is and will be bone stock
post #44 of 50 Old 12-26-2012, 07:30 AM
DeejayZeejay
1994 ZJ
I used 80/90 and it works just fine.
Jeeps 4 Life!
DeejayZeejay is offline
post #45 of 50 Old 02-19-2013, 10:38 AM Thread Starter
donutman07
1987 MJ Comanche
i finally got the jeep done and ready for the road, although the heater core i am told is bad it doesnt blow out very hot. so far to date with parts and labor im into the comanche for a little under 3 grand
5spd help crockett07 XJ Cherokee Technical Forum 7 07-16-2012 02:49 PM
AMC-290 V8 + AX-15 5spd + MJ AMC-20 ! AMCSportTruck MJ Comanche Technical Forum 35 05-05-2011 02:16 PM
How good is a 4x4 5spd shortbed Comanche as a starting point? jfman MJ Comanche Technical Forum 39 01-30-2011 12:16 AM
question about comanche 5spd tranny dontknow MJ Comanche Technical Forum 1 05-17-2009 12:59 PM
NSS on a 5spd? Marine_Psycho XJ Cherokee Technical Forum 6 12-22-2006 10:08 AM
