87 comanche 4x4 4.0 5spd - Page 2 - JeepForum.com
post #16 of 50 Old 09-19-2012, 07:33 PM Thread Starter
donutman07
1987 MJ Comanche
the only bad thing is the drivers side floorboard is pretty well rotted away and the other side is ina little better shape, does anybody have any ideas on how to fix it cheap? but making it last also, so far it will be just a winter beater but if it drives good and doesnt act up i may keep it londer and fix it up even more.
donutman07 is offline
post #17 of 50 Old 09-19-2012, 07:57 PM Thread Starter
donutman07
1987 MJ Comanche
does anyone have any ideas on how to deal with the rusted out floor pans on the drivers side and on the passenger side?
post #18 of 50 Old 09-20-2012, 07:02 AM
97_4popper
They have to be cut out and replaced.
Go over to comancheclub.com.
All you want to know about these trucks.
There are multiple threads in the your projects section of people replacing their pans....
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #19 of 50 Old 09-20-2012, 01:36 PM
Mishimoto
Vendor
Mishimoto's Avatar
I would highly recommend doing this as well. A short cut in rust repair is a bad idea.
Mishimoto is offline
post #20 of 50 Old 09-20-2012, 04:02 PM Thread Starter
donutman07
1987 MJ Comanche
1
post #21 of 50 Old 09-20-2012, 04:05 PM Thread Starter
donutman07
1987 MJ Comanche
sorry for the 2 or 3 post about the same thing i diddn't see there was a second page.
post #22 of 50 Old 11-10-2012, 11:44 PM Thread Starter
donutman07
1987 MJ Comanche
i am gonig to be working on my jeep comanche in a few weeks and i was wondering if i change the fluids all the way around what do i need to buy for what and how much do i need to buy for it. thanks
post #23 of 50 Old 11-11-2012, 09:52 PM
ftpiercecracker
1990 MJ Comanche
5 quarts of 10w30 motor oil, LOTS of gear oil 80w90 (10 quarts?) for transmission/Tcase/differentials , DOT3 brake fluid, power steering fluid dont think there is a special kind.
and some antifreeze if you are going to flush the radiator, probably 2 jugs.
ftpiercecracker is offline
post #24 of 50 Old 11-12-2012, 05:08 AM
DeejayZeejay
1994 ZJ
Tcase takes atf....
Jeeps 4 Life!
DeejayZeejay is offline
post #25 of 50 Old 11-12-2012, 06:58 PM
ftpiercecracker
1990 MJ Comanche
Originally Posted by DeejayZeejay View Post
Tcase takes atf....
I'll be honest i've never changed my Tcase fluid, i just assumed it used gear oil , if my trany does why wouldnt it? Although i will admit it does suprise me alot to hear it uses ATF, which begs the question, what kind?
post #26 of 50 Old 11-12-2012, 08:57 PM
97_4popper
TCase does take ATF. I just put new fluids in mine last year when I switched over to manual tranny from the auto.
Gear oil in the tranny and ATF in the transfer case. I don't remember what kind I used, but it was pretty standard stuff.
My build thread:
post #27 of 50 Old 11-13-2012, 11:37 AM Thread Starter
donutman07
1987 MJ Comanche
ok thank you for letting me know that, so do you think that 10 quarts of gear oil will be enough to get the tranny and diffs. do i need anythnig special for the transmission or will just regular straight gear oil be fine?
post #28 of 50 Old 11-13-2012, 02:22 PM
ftpiercecracker
1990 MJ Comanche
I used 4 and a half quarts in the tranny and a quart and half for each differential. 7 and half total.
post #29 of 50 Old 11-29-2012, 07:19 PM Thread Starter
donutman07
1987 MJ Comanche
i was wondering since the jeep only comes with one set of keys is there a place where i can get key blanks, so i can get acouple more sets made and will any place that does keys be able to make copies for me?
post #30 of 50 Old 11-30-2012, 06:13 AM
97_4popper
Should be able to at any hardware store that makes keys.
If not, check online. I've seen them on ebay.
My build thread:
5spd help crockett07 XJ Cherokee Technical Forum 7 07-16-2012 02:49 PM
AMC-290 V8 + AX-15 5spd + MJ AMC-20 ! AMCSportTruck MJ Comanche Technical Forum 35 05-05-2011 02:16 PM
How good is a 4x4 5spd shortbed Comanche as a starting point? jfman MJ Comanche Technical Forum 39 01-30-2011 12:16 AM
question about comanche 5spd tranny dontknow MJ Comanche Technical Forum 1 05-17-2009 12:59 PM
NSS on a 5spd? Marine_Psycho XJ Cherokee Technical Forum 6 12-22-2006 10:08 AM
