'86 MJ 2.8L replacement motor? - JeepForum.com
post #1 of 4 Old 10-09-2013, 10:33 AM Thread Starter
Jeep_Fanatic
2012 MK Compass
One of my co workers informed me that i could swap the crappy 2.8 with a small block 350 and it will bolt in fine.
Thoughts? Knowledge?
-Rescue Green '12 Compass Sport 4x2 2.4L CVT daily driver
-New jeep coming soon
Jeep_Fanatic is offline
post #2 of 4 Old 10-09-2013, 10:56 AM Thread Starter
Jeep_Fanatic
2012 MK Compass
Im also considering these..
post #3 of 4 Old 10-09-2013, 12:05 PM Thread Starter
Jeep_Fanatic
2012 MK Compass
Originally Posted by Jeep_Fanatic
One of my co workers informed me that i could swap the crappy 2.8 with a small block 350 and it will bolt in fine. Thoughts? Knowledge?
Im looking for a motor i can do an easy swap out. One that has carburetor and mechanical fuel pump. And less vacuum lines please! I wanted a 4.0 but thats more work and changes. So im sticking with the GM hookups available now.
post #4 of 4 Old 01-18-2014, 11:23 PM
Caish
1987 XJ Cherokee
I would go find a salvage engine 3.4L from a Camaro or Firebird with the least miles.
You will have to add your intake/carb and distributor, would be the easiest swap
and give the best bang for the buck for a performance increase.
You might need a flywheel/flexplate this route if the balance is different.
Sure you can drop a SB in it, but your going to need to fab motor mounts, and find a bellhousing,
maybe even a whole tranny...
Join us on Jeeperz Creeperz on Google+
Facebook: Arkansas Jeeps
Caish is offline
