-   MJ Comanche Technical Forum (http://www.jeepforum.com/forum/f53/)
-   -   '86 MJ 2.8L replacement motor? (http://www.jeepforum.com/forum/f53/86-mj-2-8l-replacement-motor-1666625/)
Jeep_Fanatic 10-09-2013 11:33 AM
One of my co workers informed me that i could swap the crappy 2.8 with a small block 350 and it will bolt in fine.
Thoughts? Knowledge?
Jeep_Fanatic 10-09-2013 11:56 AM
1 Attachment(s)
Im also considering these..
Jeep_Fanatic 10-09-2013 01:05 PM
Originally Posted by Jeep_Fanatic
One of my co workers informed me that i could swap the crappy 2.8 with a small block 350 and it will bolt in fine. Thoughts? Knowledge?
Im looking for a motor i can do an easy swap out. One that has carburetor and mechanical fuel pump. And less vacuum lines please! I wanted a 4.0 but thats more work and changes. So im sticking with the GM hookups available now.
Caish 01-19-2014 12:23 AM
I would go find a salvage engine 3.4L from a Camaro or Firebird with the least miles.
You will have to add your intake/carb and distributor, would be the easiest swap
and give the best bang for the buck for a performance increase.
You might need a flywheel/flexplate this route if the balance is different.
Sure you can drop a SB in it, but your going to need to fab motor mounts, and find a bellhousing,
maybe even a whole tranny...
The time now is 02:47 AM.
