86 Comanche v6 help - JeepForum.com
post #1 of 3 Old 02-15-2012, 09:24 AM Thread Starter
covertryan12
My 86 Comanche v6 won't stay running it has little power on take off but acts normal after a couple sec. What could be wrong?
covertryan12 is offline
post #2 of 3 Old 03-18-2012, 01:11 AM
carnuck
1984 J-Series Truck
it's carbed
"Usually found in a Jeep near Reiter, WA"
FOR SALE STUFF
'81 Eagle wagon with upgrades $2500
'87 Comanche shortbox 4.0/AW4/NP242 on 33" tires $3500
carnuck is offline
post #3 of 3 Old 03-18-2012, 03:49 AM
5-90
5-90's Avatar
1988 XJ Cherokee
It has the V6?
Seriously - I had an 85 Cavalier with that engine, it's a joke. The 3.1 is a far superior engine, even being the same family!
Either you're having carburettor trouble, or your ignition coil may be on its way out. Take a DMM and check the coil - then heat it up with a hair dryer and check again (heat-soaking can cause goofy things in coils.)
Also, check output at the ignition control module - should be a standard GM part, since AMC bought that engine along with its controls. Heat does even weirder things with solid-state electronics...
"recon" (sic - reckon)(tm) "hihgly"(tm) "seceed"(tm)
"Outback AIDS - Alcohol-Induced Dizzy Spells"
5-90 is offline
