86 comanche trouble - JeepForum.com
post #1 of 15 Old 09-17-2012, 06:05 PM Thread Starter
goatroper57
86 comanche trouble
hello all
i have an 86 comanche its running but when i drive it it gets up to about 40 mph or so and then starts buckin like its starvin for gas so i replaced the fuel pump and no change i do have a barrel filter between the gas tank and carb. on the inside fender wall and i see ther is a lot of air bubbles in it when its running and for a little bit after its shut off then after a whyll the barrel filter it dose not have any gas in it at all the filter is new i allso change the filter in the carb. to i drove it to day and when i was comin back home i have to go up a hill about 1/2 mile long and i had to let off the gas goin up it all most to an idle before i got up the hill what could be cusin the problem can any one help please
thanks
goatroper57
goatroper57 is offline
post #2 of 15 Old 09-17-2012, 06:55 PM
mj40
1989 MJ Comanche
2.1/2.5 or 2.8l...
fuel pump in the tank- did you replace the hose on the pump to the sending unit.... thinking maybe its split and recurculating fuel in the tank and your not getting the right fuel psi as well air mixed in it..
or
engine driven fuel pump... the sending unit pick up pipe is rotten/holes or lines leaking and sucking air in..
mj40 is offline
post #3 of 15 Old 09-17-2012, 08:03 PM Thread Starter
goatroper57
thanks for the fast reply and its a 2.8l engine driven fuel pump where is the sending unit pick up pipe
post #4 of 15 Old 09-18-2012, 04:48 AM
mj40
1989 MJ Comanche
in the tank, only good pic of one i could find..
http://www.ebay.com/itm/New-NOS-86-J...-/271048773289
mj40 is offline
post #5 of 15 Old 09-18-2012, 07:02 AM
Rican142
Im havein the same prob but its when I'm goin cryisin at a faster speed Like 50 nd up. But if I give it more gas it stops doin it for a sec till the rest of the truck catches up. Might I need bigger injectors? Or a faster fuel pump
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #6 of 15 Old 09-18-2012, 03:19 PM
mj40
1989 MJ Comanche
4.0l? your fuel psi will need to be checked...maybe bad fuel pressure regulator or a weak fuel pump
mj40 is offline
post #7 of 15 Old 09-18-2012, 04:22 PM Thread Starter
goatroper57
thank you mj40 so i guess ill have to take the gas tank out to get to that part right one good thing i have another truck just like tis one for parts i think ill just swap gas tanks and hope for the best again thank you for the info. mj40 ill let ya know how thing went after i get it swaped it mite be a few days or more before ican get to it thou later all
post #8 of 15 Old 09-18-2012, 04:39 PM
mj40
1989 MJ Comanche
your sending unit will be on the topside of the tank...likly better to swap tank as if you disturb the sending unit you will need a new seal and lock ring most times..
good luck..
mj40 is offline
post #9 of 15 Old 09-18-2012, 06:11 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Whoa!! He has a 2.8 V-6 with an engine mounted pump as stated in Post #3..
cruiser54 is offline
post #10 of 15 Old 09-18-2012, 06:32 PM
Rican142
Yes its a 4.0
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
post #11 of 15 Old 09-18-2012, 06:36 PM
mj40
1989 MJ Comanche
Originally Posted by cruiser54 View Post
Whoa!! He has a 2.8 V-6 with an engine mounted pumpas stated in Post #3..
hey, i'll be like you and not read it all and bump up my post counts
mj40 is offline
post #12 of 15 Old 09-18-2012, 07:20 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Read Post #3!!
And, 4.0 didn't come out til 1987. Who isn't reading?
post #13 of 15 Old 09-18-2012, 07:36 PM
mj40
1989 MJ Comanche
Read Post #3!!
ok, i'll keep up, theres 2 poster in this posting..
1st post was 86 2.8
2nd is 89 4.0
mj40 is offline
post #14 of 15 Old 09-18-2012, 07:40 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
1st post was 86 2.8
2nd is 89 4.0
Ah, yes. Hijacks are always so helpful, aren't they?
post #15 of 15 Old 04-21-2013, 12:19 AM
Rican142
Figured out what the problem was, it was a bad oxygen sensor and cracked distributor, replaced that and it was smooth sailing
64 Ford F-100
89 Jeep Comanche
97 Jeep Wrangler
Rican142 is offline
87 comanche srhdog90 MJ Comanche Technical Forum 8 04-08-2012 04:47 PM
86 comanche fernjohn MJ Comanche Technical Forum 1 10-02-2010 09:18 PM
new to comanche's 94xj-86mj MJ Comanche Technical Forum 1 04-08-2010 08:01 AM
How This Comanche Look? Gnl.Weirdness MJ Comanche Technical Forum 27 04-05-2010 01:50 PM
Trouble Code Trouble!!! Jeepthing88 XJ Cherokee Technical Forum 7 04-08-2006 03:32 PM
