86 Comanche - JeepForum.com
post #1 of 4 Old 04-10-2008, 11:10 AM Thread Starter
yerington06
86 Comanche
Hi there. i'm new to this forum. I have a 06 Rubicon, but it is my weekend toy. I bought a 1986 Comanche about a year ago. I rushed into it, against my sometimes better judgement.Any way, my problem is that the engine won't run or idle after about two weeks, I clean the plugs, and it will run ok for about another two week or so, then foul out. It has a Webber carb on it, and will not lean out. I use it every day to go to work. I was wondering about a cheap swap, and what it would entale. I have the 2.8 V6, 4wd and automatic. If I tried to swap a 4.0 in, will the rest of my drive train be able to stay ( bell housing, transmission, transfer case), and how hard would it be to to wire up the the engine compartment. I have heard that a 3.4L V6 from GM will bolt up, but haven't been able to find any info. Does anyone have any information I can download to guide me thru this? Thanks for any help.
yerington06 is offline
post #2 of 4 Old 04-12-2008, 09:05 AM
maddzz
1989 MJ Comanche
Check out comancheclub.com I think someone there did the 3.4 swap.
maddzz is offline
post #3 of 4 Old 05-03-2008, 09:11 PM
sandmanwv
1955 CJ2
2.8 to 3.7
The 3.7 is the same block as the 2.8 and will bolt up to your 86 MJ (Chrysler) automatic transmission.
The 3.7 is a 60 degree engine that GM used as a replacement crate engine for the later model S-10s and were used in Firebirds and Camaros for a couple of years.
I have an 86 Comanche Deluxe that I have completely rebuilt mechanically and thinking about new paint.
I had the original 2.8 bored .020 with new rods and pistons, rings, new oil pump, new timing gear and chain. Crank turned .010. New valve guides, seats, valves and springs. New distributer and I lucked up and found a new Rochester 2SE carburetor for $200.00 on ebay
sandmanwv is offline
post #4 of 4 Old 05-04-2008, 01:15 AM
shdbriding
If you decide to sell the webber carb let me know.
shdbriding is offline
No more oil under Comanche now PitBull4X4 MJ Comanche Technical Forum 0 07-28-2009 12:26 AM
Looking for another Comanche '88 Red Devil MJ Comanche Technical Forum 7 04-12-2008 05:01 PM
Here's my Comanche Country Jeep XJ Cherokee Technical Forum 4 10-26-2004 08:25 AM
Comanche V8 JERSEYJOE XJ Cherokee Technical Forum 1 10-01-2004 05:58 PM
comanche? j33p3rs XJ Cherokee Technical Forum 3 08-23-2004 07:04 AM
