85 cherokee engine swap - JeepForum.com
post #1 of 5 Old 12-14-2012, 03:23 PM Thread Starter
Glance
I have a 85 model cherokee that has the 2.5 4 cylinder engine that is blown up, i want to upgrade to a 6 cylinder, i'm trying to figure out what size 6 cylinder ( 4.0, 4.2) would swap into this vehicle fairly cheap. I've got a chance to purchase a wrecked 96 model cherokee that has the 4.0 in pretty reasonable. any assistance would be greatly appreciated.
Glance is offline
post #2 of 5 Old 12-15-2012, 08:27 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Neither. Lots of work. Trans is too weak and won't bolt up. The firewall will be in the way.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
post #3 of 5 Old 12-15-2012, 06:31 PM
ftpiercecracker
1990 MJ Comanche
Cruiser, 2.5s never came with the AX-15?
ftpiercecracker is offline
post #4 of 5 Old 12-15-2012, 08:00 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I don't think so.
post #5 of 5 Old 12-16-2012, 09:01 PM
97_4popper
AX4 or AX5 I believe depending on if 4 sp or 5.
Some of the older ones probably have the Puke Goat.
don't think the 4 popper ever came with an AX15.
If it did, it sure would make the v8 swaps easier.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
