6-8 inch lift!!' - JeepForum.com
post #1 of 20 Old 03-21-2012, 05:42 PM Thread Starter
BigRedWilkey
6-8 inch lift!!'
What are some options to get 6-8 inches of lift on my MJ? It is a 1990 with 4wd
BigRedWilkey is offline
post #2 of 20 Old 03-22-2012, 06:04 AM
86customanche
1992 MJ Comanche
Rustys has a 6.5" kit. Itll take quite a lot of work but if you put the time and effort into it, it will certainly look great.
Brian
86customanche is offline
post #3 of 20 Old 03-22-2012, 08:08 AM Thread Starter
BigRedWilkey
They have an 8 inch one also but my question I have with it is wether or not it's an SOA. I was hoping for something cheaper as well. I'm thinking of putting a 8.25 Chrysler rear end in her and I was wondering of I could transfer the xj springs over when I do it and do an SOA and do an add a leaf or even a bigger xj leaf spring. if its possible to go this route I would just do an 10 inch xj lift in the front (because of the rake). is this even possible??? Thanks for your time!
post #4 of 20 Old 03-22-2012, 08:22 AM
86customanche
1992 MJ Comanche
Im pretty sure any brand lift kit over 5" will be SOA. The XJ leafs will NOT fit. Youll have to find MJ springs in a JY or buy new ones. You can, however, put an XJ add-a-leaf in a MJ pack, will make the lift different than stated but it will fit.
Brian
post #5 of 20 Old 03-22-2012, 11:20 AM
OriginalNVMJ
1992 MJ Comanche
6-8 inch kit
There are no quality kits available for MJs for that lift height, you will have to do a hybrid lift kit. Save yourself a lot of money and heartache, buy a quality 4 link long arm upgrade kit (BDS) Trackbar (R/K) Front coils (T&T) You will have to put together you own soa set-up. Use long heavy duty perches, heavy duty shock mounts. SOA w/ new MJ springs gets you 6 1/2 in lift. If you want it to sit level your front needs to be 7 1/2 in lift. If you want the rear end stiffer you will have to add leafs arched to match your leafs at ride height.
OriginalNVMJ is offline
post #6 of 20 Old 03-22-2012, 04:53 PM
bravojmc
1987 MJ Comanche
O god.. My 6.5 Rustys long arm is well made and works very well! everyone can't afford a Clayton $3500 kit! lol Go with Rustys 6.5 long arm kit youll love it.
Get in sit down and shut the F#%* up!
bravojmc is offline
post #7 of 20 Old 03-22-2012, 07:32 PM Thread Starter
BigRedWilkey
What about he rusyzs 8 inch lift? Does anyone have experience with that lift?
post #8 of 20 Old 03-22-2012, 08:11 PM
bravojmc
1987 MJ Comanche
Just asking. Why do you want to go 8"?
bravojmc is offline
post #9 of 20 Old 03-23-2012, 11:45 AM Thread Starter
BigRedWilkey
I am planning on 37 inch tires
post #10 of 20 Old 03-24-2012, 06:40 AM
dkroll
1988 MJ Comanche
I am working on a Rusty's 8" Long arm, but just starting on it, I am still working on the first step which is removing the lower control arm brackets, SLOW GOING for me, just a little at a time. Working on a Ford 8.8 rearend SOA and purchasing a G2 Dana 44 Axle. Can't wait to get it to be a rolling frame from this stage!
Doug
dkroll is offline
post #11 of 20 Old 03-24-2012, 04:50 PM Thread Starter
BigRedWilkey
Awesome! Keep me posted on how its going!
post #12 of 20 Old 08-21-2012, 10:30 AM
dkroll
1988 MJ Comanche
Just got the front axle under it so it will roll around, but what a nightmare so far! I have so much more work to do! In order to play with the front-end settings, I must weigh down the vehicle (i.e.. stick the engine, tranny and xfer case ) under it for proper adjustments/ bracket welding locations!
This project is not easy nor fun, but will eventually be worth the blood, sweat and tears!
Doug
dkroll is offline
post #13 of 20 Old 08-21-2012, 10:33 AM
dkroll
1988 MJ Comanche
And rims/tires!!
Doug
dkroll is offline
post #14 of 20 Old 08-27-2012, 10:16 PM
dkroll
1988 MJ Comanche
Rust's 8.5 lift has no good instructions, and if I were to call them tomorrow, it would be just like a law firm,,,got you by the balls so they can sell you more because they don't know what you are doing first hand!!! I am very pleased by their products so far, just their instructions suck! They would be one of our many choices, if they could show us the process and if they would just sponsor me in this project! I would like to give some "productive" information on this product.
Until then, I guess I need to get back to the grinder!
I love this lift. I have the whole drive train out of it, and with a SOA on the back- without going to the 8.8 Ford (which is bigger), Everything is going to lay out to 8-10 inches.
I am happy about this, this gives me the space I wanted to keep her "stock-looking" with the most lift and not stupid mud tires- more so,,,
as a proudly daily driver. Just saying.
Doug
dkroll is offline
post #15 of 20 Old 09-06-2012, 10:01 PM
cody4359
1987 MJ Comanche
when i got my mj it was at about 7" lift with SOA + shackles and RE long arm. since then i have cut that off and put on a RK 3 link. install was a bit of a pain drilling the holes but it fit nicely and is stout. its not everyones cup of tea but if you want big tires without such a tall center of gravity you can use bumpstops to limit uptravel/ put on some cutout flares like bushwacker or napier 2 door xj flares
cody4359 is offline
