4x4 swap on my 88 mj - JeepForum.com
post #1 of 3 Old 11-16-2012, 06:34 AM Thread Starter
TheComancheKid
Ok so my mj is a4.0 5speed 2wd at the moment im getting all my stuff together for my 4x4 swap have a np231 case and a hp dana 30 i was wondering if my 231 case will bolt rite up and what else would i need to complete my swap
TheComancheKid is offline
post #2 of 3 Old 11-16-2012, 11:13 AM
97_4popper
Your transmission will not work without changing the tail shaft.
Your driveshaft will need to be altered or replaced with a shorter one.
You will need the transfer case linkage.
Your best bet would be to find a donor rig.
You need to make sure your front axle has the same gear ratio as your rear or one will have to be changed. Or both if you don't like either ratio.
This is what I can think of off the top.
Head over to comancheclub.com for all the information on these trucks that you will ever need.
Really, your best bet is to find a donor cherokee or comanche 4x4 5sp that you can just swap everything over from.
Nice looking truck.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #3 of 3 Old 11-17-2012, 07:44 PM
Pete M
1988 MJ Comanche
what is the input spline count on the t-case? it'll need to match your 4wd trans. Hopefully it's 23 spline so you can use it behind the AX-15 you'll be getting(your current trans is the very undesirable BA-10/5 Peugeot). what is the gear ratio in the dana 30? It'll need to match the rear axle. or more specifically, you'll want to take this opportunity to upgrade the ratios so your truck doesn't become an absolute dog when you go to bigger tires.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
