4x4 problems - JeepForum.com
post #1 of 12 Old 09-17-2012, 06:59 PM Thread Starter
BryceBrown
1987 XJ Cherokee
4x4 problems
I have an 87 cheroke. Wjen i first bought the jeep i lmew the fourwheel drive wasnt working do to the linkage. After replacing the linkage and the bushings it worked great but when i went out on the trails i coulsdnt get the four wheel drive to engage i positive my transfer case is good i heard the actuator housing could be bad now is the housing on the front axle the whole unit or is there another actuator somewere else
BryceBrown is offline
post #2 of 12 Old 09-17-2012, 11:38 PM
FujativeOCR
2011 MK Patriot
This is in the Patriot forum. Repost in Cherokee perhaps?
FujativeOCR is offline
post #3 of 12 Old 09-18-2012, 04:12 PM
jasonwe
2012 MK Compass
Maybe a moderator can move the thread over to the right section.
2012 Jeep Compass Sport 4x4
2.4L I4, CVT II, Freedom Drive I
2010 Dodge Dakota Quad Cab 4x4
4.7L V8, 545RFE, Big Horn Edition
jasonwe is offline
post #4 of 12 Old 09-19-2012, 07:18 AM
IRSmart
2015 KL Cherokee
the first problem is you should never lmew the four wheel drive. NEVER.
IRSmart is offline
post #5 of 12 Old 09-19-2012, 11:47 AM
Pete M
1988 MJ Comanche
this mod will rid you of the awful CAD and get you going (and never have that problem again!)
http://comancheclub.com/topic/17377-cad-fix-1/
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #6 of 12 Old 09-19-2012, 03:55 PM Thread Starter
BryceBrown
1987 XJ Cherokee
if i do this will it keep me in four wheel drive all the time i want to me able to take it out and put it backk in
post #7 of 12 Old 09-19-2012, 03:56 PM Thread Starter
BryceBrown
1987 XJ Cherokee
and thanks for the help since i messed up where i put the post
post #8 of 12 Old 09-19-2012, 04:05 PM
Pete M
1988 MJ Comanche
no. 4wd is controlled by your t-case and only your t-case. this mod simply takes the 2-piece shaft and makes it essentially a 1-piece shaft. Jeep did away with the silly CAD design in the early 90s and all Jeeps since have come with a 1-piece shaft.
the only downfall is that if your front driveshaft ujoints are bad, they will vibrate at speed. not really a downfall though, since if they need to be replaced, you should replace them.
My email:
Pete M is offline
post #9 of 12 Old 09-20-2012, 08:19 PM
ftpiercecracker
1990 MJ Comanche
Pete M you are one slick son of a gun, you steal all the posts that i might actually be able to help with. And as for you BryceBrown, listen to the man.
ftpiercecracker is offline
post #10 of 12 Old 09-23-2012, 06:08 PM Thread Starter
BryceBrown
1987 XJ Cherokee
I appreciate it and im going to make the switch this weekend and get it fixed just making it my project jeep
post #11 of 12 Old 09-24-2012, 11:33 AM
NHJeepbuilder
Or you could replace the passenger side axle shaft with a 1 piece Cherokee axle shaft and fabricate a cover to eliminate the cad vacuum fork.
NHJeepbuilder is offline
post #12 of 12 Old 09-25-2012, 09:34 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Too much work.
cruiser54 is offline
