4 wheel drive not working - JeepForum.com
post #1 of 8 Old 07-25-2012, 09:37 PM Thread Starter
mj86
1986 MJ Comanche
Went thru some mud and got stuck to deep. Every since when I try to shift into 4 high or 4 low doesn't engage. Thanks to the ones who helped me with my last problem. Any help is greatly appreciated.
mj86 is offline
post #2 of 8 Old 07-26-2012, 07:51 AM
97_4popper
Probably something wrong with the vacuum disconnect.
Check the vacuum lines from the transfer case up to the connection up to the axle.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #3 of 8 Old 07-28-2012, 05:59 PM
Pete M
1988 MJ Comanche
or rid yourself of the headache once and for all and never worry about it again.
http://comancheclub.com/forums/viewt...hp?f=9&t=18415
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #4 of 8 Old 07-29-2012, 06:54 AM
97_4popper
Yup.
I did that.
Works great.
My build thread:
post #5 of 8 Old 07-31-2012, 05:59 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Here's the answer. Done it to all of mine.
cruiser54 is offline
post #6 of 8 Old 08-08-2012, 10:02 AM Thread Starter
mj86
1986 MJ Comanche
lost 4 wheel drive
vacuum is all good, found out that when I drop the transfer case when I put the 4.5 lift on the shift lever came disconnected. Now it will not line up. any suggestions?
mj86 is offline
post #7 of 8 Old 08-08-2012, 08:04 PM
jakesjeepmj1988
1988 MJ Comanche
You need a transfer case linkage drop i have one i got in a 4" RC tj lift kit
jakesjeepmj1988 is offline
post #8 of 8 Old 08-09-2012, 10:52 PM Thread Starter
mj86
1986 MJ Comanche
Thanks
mj86 is offline
4 WHEEL Drive Clunk-Worn Drive Shaft/Differential Gears? Jeeps4u XJ Cherokee Technical Forum 14 11-18-2014 09:22 PM
4 Wheel drive not working mwitkowski24 XJ Cherokee Technical Forum 15 12-03-2011 02:17 PM
4 wheel drive not working pwmach1 XJ Cherokee Technical Forum 1 05-17-2010 05:34 PM
4 Wheel Drive Not Working purpleliftedxj XJ Cherokee Technical Forum 12 09-02-2008 07:10 PM
4 wheel drive not working... jugger XJ Cherokee Technical Forum 4 12-15-2002 02:29 AM
