4.0 Fuel injectors - JeepForum.com
post #1 of 17 Old 01-09-2012, 08:24 AM Thread Starter
Dafish
4.0 Fuel injectors
I have a 1992 Comanchee with 4.0, a guy mentioned I could get better performance and gas mileage if I changed the OEM injectors with Bosch injectors, He said they have 4 port small port holes instead of one big one. Has anybody installed these and if so what is your opinion? Thanks
Dafish is offline
post #2 of 17 Old 01-09-2012, 03:49 PM
Programbo
1994 XJ Cherokee
Hello. Yes going from the single port stock injectors to the 4-port ones is one of the most common upgrades that can be done to a Jeep. Generally people use the Bosch 703 "Neon" injectors as they are the same flow rate as the stock Jeep ones and are a direct swap out. The main advantages are you get a smoother idle, quicker starts and a better throttle response and acceleration because of the better fuel atomization.
Programbo is offline
post #3 of 17 Old 01-10-2012, 04:50 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Another real big advantage is the new injecotrs don't split at a crimp like the originals and spray raw gas on your exhaust manifold.
This guy also has an ebay store and the prices are for a set of 6 injectors:
http://www.precisionautoinjectors.co...7&categoryId=3
cruiser54 is offline
post #4 of 17 Old 01-10-2012, 06:02 AM
Programbo
1994 XJ Cherokee
Hmmm. I'm not sure what injector he is showing there in those photos. They arent any of the most common "upgrade" Jeep injectors I think they are just rebuilt and tested stock injectors.
post #5 of 17 Old 01-10-2012, 06:10 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The ones I got were Ford Yellow-top and Orange-top, 4 hole units. I've installed his injectors on 3 Renix Jeeps now.
They are rebuilt, flow-matched and come with new o-rings. The upgrade is that they're 4 hole instead of single hole.
post #6 of 17 Old 01-10-2012, 04:58 PM
Programbo
1994 XJ Cherokee
Sounds about right. But I think that photo is showing just basic single port Chrysler injectors.
post #7 of 17 Old 01-10-2012, 05:06 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Could be a generic photo.
post #8 of 17 Old 01-10-2012, 07:16 PM Thread Starter
Dafish
So, do you get better gas mileage with them also?
Dafish is offline
post #9 of 17 Old 01-10-2012, 08:03 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Didn't really notice. We both do mostly around town driving. Idle quality and throttle response were both improved. And the fact that the new style injectors don't cause Car-B-Ques like the originals is a bonus.
post #10 of 17 Old 01-13-2012, 04:44 PM
Programbo
1994 XJ Cherokee
Some people see an increase in mpg but that's usually because they are swapping out very dirty poorly performing injectors for new ones. If your stock injectors arent overly dirty your mpg won't change much.
post #11 of 17 Old 01-13-2012, 04:51 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
I agree. And, the stock Renix injectors are a fire waiting to happen.
post #12 of 17 Old 01-19-2012, 12:32 PM
bravojmc
1987 MJ Comanche
Why are they a fire waiting to happen...?
Get in sit down and shut the F#%* up!
bravojmc is offline
post #13 of 17 Old 01-19-2012, 02:29 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
The original injectors on the Renix Jeeps were made by Siemens-Deka. They had a crimp on the body of the injector which in time could spring a leak spraying raw gasoline on to the exhaust manifold.
The upgrade injectors are Bosch and have no crimp.
post #14 of 17 Old 01-19-2012, 05:00 PM
Programbo
1994 XJ Cherokee
But to be fair that rarely happens. Yes it CAN happen because of the injector design but it's not a common event so I wouldn't lose sleep over it.
post #15 of 17 Old 01-19-2012, 05:32 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Only needs to happen once. And besides, the upgraded injecotrs and new seals are about due at this point anyway.
