2wd Comanche?? - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > 2wd Comanche??
07-13 Wrangler 17x9 Wheels Free Shipping + $50 RebateHID's from RuffStuff!Ruffstuff Axle Simple Swap Kit!
Unread 11-30-2005, 04:18 PM   #1
NWDave
2wd Comanche??
I'm looking around for a cheap project vehicle, and came accross an '88 MJ with a Dana 35 3:55 geared rear, auto trans, and 2wd. It has a column shift too.
Would a 4wd conversion be out of the question for this truck, or should I just keep looking and get an original 4wd MJ?
2007 JK-X 2dr soft top, OME MD/Bilstein 5100's= 3.5" lift, 15x8" Cragar Soft 8's, 35x12.50-15 BFG KM2's.
NWDave is offline   Reply With Quote
Unread 11-30-2005, 04:31 PM   #2
DirtyCommanche
Conversion is easy. However, you normally wind up being better off just starting with a 4x4 one, as you'll need a cherokee for a parts donor.
Does it have a 4.0?
Are you looking to go big (35" or bigger tires)? If so, I'd be buying an old fullsize for an axle donor.
DirtyCommanche is offline   Reply With Quote
Unread 11-30-2005, 04:35 PM   #3
NWDave
I can find XJ's around here fairly easy, but I need a truck, to haul stuff, and I already have a new Wrangler Unlimited. I wasn't wanting to go any bigger than 31's or 32's.
Yes, it's a 4.0L, with 157,000 miles on it.
Unread 11-30-2005, 04:42 PM   #4
DirtyCommanche
Well, I'd say look for a 87-88 cherokee with D44 rear (why not), 4.0/auto. Steal the tranny, tcase, front and rear axles, and front driveshaft. I'm probably forgetting about a million things you'll need. Might keep the extra 4.0 as a spare while you're at it...
You'll also need to get the rear shaft cut down, or go see a junkyard.
Unread 11-30-2005, 04:43 PM   #5
Dana44
to convert you need
COMPLETE front axle
Transmission and transfer case case
front and rear drive shafts
cross memebers
don't forget, gotta have the same ratio gearing in the front, as well as the back
Dana44 is offline   Reply With Quote
Unread 11-30-2005, 04:43 PM   #6
Ed in North Ga
1989 MJ Comanche
really depends on the price, and you location-
an MJ thats 2wd is a good truck as is...I should know
an MJ thats 4wd is better...if you "need" the 4wd.
conversion, like stated above, is easy-most everything you need is available on a 4wd donor...if you have a donor...if you dont, your buying two vehicles to make one...in which case you may have been better off buying one with 4wd already.
[URL=http://groups.msn.com/RattsNest]Ratts Nest [/URL] 1989 Jeep MJ- 200,000- 28mpg. If its a Renix, its all good. 1989 XJ (sold) 310,000- 29mpg. Renix. See the pattern?
Ed in North Ga is offline   Reply With Quote
Unread 11-30-2005, 04:45 PM   #7
DirtyCommanche
Often enough people need cherokee stuff that you can recoup costs by parting them out.
Unless you live in the boonies like me, and had to GIVE away a perfect body MJ.
Unread 11-30-2005, 05:21 PM   #8
NWDave
The MJ's I see around here are either well used project trucks, like this one, or are really nice, and priced fairly high.
Unread 11-30-2005, 06:40 PM   #9
cj7xjmj
I have to agree with Ed, if you need a 4wd truck, you will come out money ahead, to just go buy one. As for being able to recoup your cost by stripping the donor vehicle.... That only works if youo have desireable parts. Right now I have 2 np242's and 2 aw4 sitting behind my garage..WHY.. no one wants an auto tranny Only if I had a few ax15's and 231's
Patrick
90 Comanche thing. Exo-cage, tube bed, with a few other things done Here is a link to some pics of it
[url]http://independent4x.com/generic67.html[/url]
[url]http://community.webshots.com/user/cj7xjmj[/url]
If you have to ask why... Its a truggy thing and you wouldn't understand
cj7xjmj is offline   Reply With Quote
Unread 11-30-2005, 08:23 PM   #10
a4xnut
1989 MJ Comanche
NWDave - are you anywhere near Kent, WA? If so, you might wanna look into the MJ for sale here:
http://www.georgethejeep.com/ForSale.html
I don't know for sure if he still has it and I haven't seen it, so I can't vouch if it's a good buy or not, but it might be worth checking out...
Since it most likely has the BA10, you could ask them about the parts to convert to the AX-15 - they've probably got everything you'd need since they have an extensive collection of Jeeps they're always parting out.
a4xnut is offline   Reply With Quote
Unread 11-30-2005, 11:34 PM   #11
NWDave
I live in Everett, and work on 3rd shift at the local discount aircraft manufacturer.
Unread 12-01-2005, 04:57 AM   #12
Ed in North Ga
1989 MJ Comanche
Patrick
"no one" would not include people (me) who like aw4s.....and have ax15s.
if you lived closer...I`d sneak over and rob you.
Unread 12-01-2005, 07:27 AM   #13
cj7xjmj
I personally love the AW4. Tough as you know what, and they have a decent first gear. Problem I have, they dont have a np231 t-case, they both have the NP242, which I really do not like, for a trail rig. If it was for a DD, or a street rig, it would be all right, but since I basically use both of my MJ's as either parts hauler, or trail rig, a NP 242 does me lil good.
Patrick
Unread 12-02-2005, 12:00 AM   #14
a4xnut
1989 MJ Comanche
Small world! I work at the same place, only 2nd shift...
I didn't realize you were here on this board until we chatted last night at shift change!
