#1 | |
LLaP \\//,
2WD to 4WD conversion??
Was just reading and I am curious how hard this is to do on the Comanche's
#2 |
I'm about to do it. you would need,
front axel, drive shaft, transfer case, and possibly a transmission.... I wouldn't do it unless you changing nearly the whole drive train then I wouldn't have decided to do it,,, but I'm changing it all...hahaha cheapest way find you a MJ 4x4 donor truck, other wise you're stuck finding parts that fit or making them fit lol |
#3 |
What you need depends on what you want to use the truck for afterwards. It's a bolt-in affair if you stick with MJ/XJ parts
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc. Also an 86 MJ Metric ton and 2 '90 MJs Projects/wheelin' pics: picturetrail.com/petermontie My email: petermontie@hotmail.com ComancheClub.com/forums |
#4 |
I am looking at just buing a cherokee with a 4 cylinder. swaping everything underneath. except for the engine and trans. I will have to find a good trans and tranfercase to go under from somewhere else.
Reason for the 4 cylinder cherokee it has the right axles and gear ratios for what I want. but you have to look to make sure what it has..... |
#5 |
I'm just finishing up my 4x4 conv. you will need a 4x4 trans, transfer case, axles and drive shafts, yours will just be longer than mine. I just bearly made the speedo cable fit so i have to lengthen wires. I have vac disco so I've been dealing with that. Get a parts jeep and swap parts
Project/DD - 95' Cherokee Sport, 2 Door, Converted to 4x4, AX-15, NP231, Black and lots of other goodies 88' Cherokee Limited - RIP Sold - 96' Cherokee Sport 4x4, 2 Door, AW4, NP242, Its the girlfriends now!! |
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
