2 inch lift 88 comanche - JeepForum.com
post #1 of 4 Old 12-06-2012, 12:32 AM Thread Starter
Hitman72
1988 MJ Comanche
(POST MOVED TO HERE)
I want a daily driver that can get through the snow and a little mud.
want to run a 2 inch lift on 31s.
what is the best bang for my buck on lift kits. ( i am in collage and money is tight) thats why i say 2 inch so i dont have to extend anything, break lines, drive shafts.....etc...
Hitman72 is offline
post #2 of 4 Old 12-06-2012, 10:00 AM
97_4popper
1990 MJ Comanche
Chevy drop shackles in the back and 2 in pucks in the front. Should net approx 2 in.
I run 31's on stock suspension w/TJ Gambler rims. The only rub point is on the control arms at full lock.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #3 of 4 Old 12-07-2012, 11:07 PM
Pete M
1988 MJ Comanche
and the rub can be cured with WJ lower control arms.
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #4 of 4 Old 02-21-2013, 10:57 PM
blucas8691
1989 XJ Cherokee
I run 33s stock. Cut the fenders and then any other metal that may rub your tires. Rear will clear no issues.
blucas8691 is offline
