Quantcast 2.5 tbi injector i need a bit of help - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > Comanche Technical Forum > 2.5 tbi injector i need a bit of help
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineDISCOUNT - Chromoly Front Axle Shaft Kits, 87-95 YJ's, 97-GR8TOPS Introduces the Exogate HD Tire Carrier
Old 03-19-2006, 11:33 PM   #1
saaca
is the tbi injector in my 2.5 comanche tbi the same as the gm unit for the 2.5..??
i just orderd a new one because i need it and was told that they are the same. im hoping that i didnt make a hunderd doller mistake...also is there a fuel pressure regulator in the retuen line for this truck?
thanks guys
saaca is offline   Reply With Quote
Old 04-17-2006, 06:57 PM   #2
saaca
i finaly got it going..a new fuel pump, tbi injector and last but not least..a pressure regulator..100 for the pump,90 for the injector and 30 for the regulator draprham...but it runs like new and its only 80k miles.
Old 04-17-2006, 11:50 PM   #3
Otahyoni
so was the injector the same? cause i might be needing one and all the prices i got were over 250$
~Chris
And all of the diodes may have committed suicide, leaving you with a fun whirly thing under the hood that produces nothing.
Otahyoni is offline   Reply With Quote
Old 04-24-2006, 10:39 PM   #4
saaca
the best injector prices anyware
check with this guy...hes great..the injector is the same but the output pressure is a bit off from what he says..i got it to my door for less than 100 bucks..i even bought the regulator kit from him for another 30 bucks to the door...
heres the ebay listing for him..you can tell him i sent you all.
http://www.docinjector.com/
Glock Forum
