1988 MJ Horn Problems - JeepForum.com
post #1 of 8 Old 11-07-2012, 01:07 PM Thread Starter
Brett486
1988 MJ Comanche
Alright guys, I have been trying to diagnose this horn problem and I can't find a clear solution. I desperately need to get my truck inspected (EXP 6/12) and the last thing on the Texas DPS list that I need is a working horn.
So I've disconnected the horn button panel from the wheel and there are two wires. One running from the column to the button and one running from the button to nowhere. I know that the second slides into a hole on the column but still does not activate the horn while the truck is running. I've looked under the front bumper, drivers side and cannot find the horn. I'm lost and this is my only day off.. I need HELP!!!
Horn:
Under the front bumper:
So as far as I can see the only thing under the front bumper is the front left turn signal. There is nothing below it, not the horn or anything for that matter.
Please, any help would be much obliged!!
Thanks,
Brett
Brett486 is offline
post #2 of 8 Old 11-07-2012, 02:35 PM
97_4popper
Not much info here.
Look everywhere. Do you have a horn or not?
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #3 of 8 Old 11-07-2012, 02:36 PM
SnowYJ
1988 MJ Comanche
So you just need a horn??
I go to college and I drive a Jeep.
SnowYJ is offline
post #4 of 8 Old 11-07-2012, 05:24 PM Thread Starter
Brett486
1988 MJ Comanche
Ok so I got it to where when I push the horn button I can hear the horn relay clicking in the fuse box which is good news. So at least I have current running through the wires. I then looked under both sides of the front bumper and found a wire on each side leading to nothing, with one having a plug on it. I'm assuming this to mean that the PO took both the horns off and now I get to replace them .
Brett486 is offline
post #5 of 8 Old 11-08-2012, 08:12 AM
Soldier905
1988 MJ Comanche
Not sure if this will help much but here is a pic of where my horn is mounted on my 88 mj
Soldier905 is offline
post #6 of 8 Old 11-08-2012, 10:20 AM
SnowYJ
1988 MJ Comanche
I tore mine off when I was trimming the fenders.. Hha
SnowYJ is offline
post #7 of 8 Old 11-09-2012, 04:46 AM
mj40
1989 MJ Comanche
same as my 86 and 89..
mj40 is offline
post #8 of 8 Old 11-11-2012, 05:57 AM
LalanP111
bump, this is a question that me and my fellow mj buddies have to yet figure out!
1998 TJ, 4.0L, RC 2.5", 31x10.5-15 Duratracs (sold)
1988 MJ, 4.0L ..soon for be on 33's and 6.5" LA/SOA (project)
2004 TJ, 4.0L, Columbia Edition, 2.5" Rough Country, 33x12.5-15 Duratracs, Quadratec Winch, Dual Top (DD, future project)
Originally Posted by Knuckelhead View Post
It takes care of me and in return, I take care of it. Takes me away from everything I don't want to be around, and back again when needed...
LalanP111 is offline
horn , mj
