1987 comanche engine turns over wont start - JeepForum.com
post #1 of 5 Old 01-13-2013, 04:50 PM Thread Starter
bob1965
hi every one im new here im a wrench on motorcycles i own an 87 comanche about 160,000 miles went to pick something up a week ago ran fine there loaded up the truck turned the key would spin and try to start but no luck ..will run on spray...so i towed it home 3 hours later i tried it and it started ...today we replaced the fuel pump with correct bosch unit the pump will run for a few seconds and turn off but i have no fuel out of the tank relay is new as is filter remember it will run on spray im missing something need my truck back any ideas thanks bob
bob1965 is offline
post #2 of 5 Old 01-13-2013, 05:32 PM
97_4popper
Is it getting fuel to the fuel rail?
Is the fuel pump running? The ground on the back is a known issue.
It is behind one of the tail lights and is a small wire attached to the bed. Take it off, clean it and lightly sand it and where it connects and reattach.
Get over to comancheclub.com.
90 MJ 4.0 4X4 5sp LB Pioneer Big Ton.
Truck contains parts from 3 MJs, 2 XJs, 1 TJ and a dishwasher.
Check out comancheclub.com...
My build thread:
Wifes: 97 TJ 2.5 4X4 5sp 31's stock. . . Slow but; reliable.
97_4popper is offline
post #3 of 5 Old 01-13-2013, 05:45 PM Thread Starter
bob1965
pump runs ill thats in the post no fuel out of tank yes theres gas in it i just noticed it will crank in park but not in neutral been a long unproductive day
bob1965 is offline
post #4 of 5 Old 01-15-2013, 06:58 PM
mj40
1989 MJ Comanche
one thought, it happened to me after replacing my tank... the new pump... did you replace the hose on the pump to sending unit and clamp it... i didnt and the hose split and just pumped fuel inside the tank and not out the sending unit..
mj40 is offline
post #5 of 5 Old 01-22-2013, 04:32 AM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
There is possibly a fuel pump ballast resistor on your driver's side inner fender. White ceramic, wire to each end, bolt through the middle. Make sure connections are tight. It's OK to bypass it.
If you own a Renix Jeep, you'll want to check this out.
An index to over 30 write-ups can be found in the link below
My Jeep Technical Photos
cruiser54 is offline
