1986 mj clutch problems - JeepForum.com
post #1 of 5 Old 03-26-2013, 08:35 PM Thread Starter
locke1
1986 MJ Comanche
I have a 1986 MJ.Ive replaced master,slave cylinders,throw out bearing and pressure plate,the clutch has been bled several times and still no clutch any ideas would be greatly appreciated.
locke1 is offline
post #2 of 5 Old 03-27-2013, 04:35 PM
ftpiercecracker
1990 MJ Comanche
did you bench bleed the MC?
ftpiercecracker is offline
post #3 of 5 Old 04-10-2013, 01:31 PM Thread Starter
locke1
1986 MJ Comanche
yes the mc has been bled,several times
locke1 is offline
post #4 of 5 Old 04-10-2013, 04:25 PM
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Try this:
Pump the pedal 40 to 50 times and walk away for 10 minutes. Do it again. Then again if still needed.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
post #5 of 5 Old 04-19-2013, 10:58 PM
theguywithjeeps
1989 MJ Comanche
try to gravity bleed the system if you don't get clutch still there is something wrong inside.
theguywithjeeps is offline
