-   MJ Comanche Technical Forum (http://www.jeepforum.com/forum/f53/)
-   -   1986 mj clutch problems (http://www.jeepforum.com/forum/f53/1986-mj-clutch-problems-1499640/)
locke1 03-26-2013 09:35 PM
I have a 1986 MJ.Ive replaced master,slave cylinders,throw out bearing and pressure plate,the clutch has been bled several times and still no clutch any ideas would be greatly appreciated.
ftpiercecracker 03-27-2013 05:35 PM
did you bench bleed the MC?
locke1 04-10-2013 02:31 PM
yes the mc has been bled,several times
cruiser54 04-10-2013 05:25 PM
Try this:
Pump the pedal 40 to 50 times and walk away for 10 minutes. Do it again. Then again if still needed.
theguywithjeeps 04-19-2013 11:58 PM
try to gravity bleed the system if you don't get clutch still there is something wrong inside.
The time now is 03:24 AM.
