1986 comanche starting problem - JeepForum.com
post #1 of 4 Old 11-26-2012, 11:47 AM Thread Starter
Lynyrd777
1986 MJ Comanche
It starting taking longer to start truck, so I installed new plugs, wires, ditributer and rotor....now it turns over and sometimes starts just for a second. From what I have read, I removed the Crankshaft positioning sensor and cleaned all the grease from the sensor re-installed but no luck. My question is..should I buy a new CPS or is there another trick I should try?
Thanks in advance
Lynyrd777 is offline
post #2 of 4 Old 11-26-2012, 03:48 PM
ftpiercecracker
1990 MJ Comanche
Before you read below, do you have a 4.0?
Check your fuel pressure at the rail. If it starts but only runs for a moment its not getting fuel and is probably a bad ballast resistor and/or fuel pump. When you turn your key to run you should hear the fuel pump kick on for a moment or two then kick off. You might have to open your door to hear it. If you dont hear it then its very possible you have a bad fuel pump/ballast resistor.
ftpiercecracker is offline
post #3 of 4 Old 11-26-2012, 04:38 PM Thread Starter
Lynyrd777
1986 MJ Comanche
It is a 2.5 litre 4WD
post #4 of 4 Old 11-26-2012, 08:18 PM
cruiser54
1990 MJ Comanche
With it started, spray throttle body cleaner around where the intake manifold meets the head and around the throttle body where that pesky vacuum block is with the 4 fittings.
If you own a Renix Jeep, you must check this out:
My Jeep technical photos:
cruiser54 is offline
