1986 comanche relays - JeepForum.com
Go Back JeepForum.com > Models > Jeep Cherokee & Comanche Forums > MJ Comanche Technical Forum > 1986 comanche relays
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 11-28-2012, 05:44 PM   #1
jahiatt
Theres a rectanular relay at the bottom of the fuse block
Can anyone tell me what it controls?
jahiatt is offline   Reply With Quote Quick reply to this message
Unread 11-28-2012, 10:46 PM   #2
ftpiercecracker
1990 MJ Comanche
http://comancheclub.com/topic/11654-door-buzzer/
According to the above picture, which one are you referring to? This image is oriented correctly, left is driver side, right passenger side, up would be the dash, down would be the floor boards.
ftpiercecracker is offline   Reply With Quote Quick reply to this message
Unread 11-29-2012, 04:59 AM   #3
jahiatt
the one at the bottom below the 75 fuse
Unread 11-29-2012, 05:49 AM   #4
cruiser54
cruiser54's Avatar
1990 MJ Comanche
Windshield wiper/washer circuit breaker.
Originally Posted by chris87xj View Post
If you own a Renix Jeep, you'll want to check this out. >
An index to over 25 write-ups can be found in Post #1.
Cruiser's Mostly Renix Tips
My Jeep Technical Photos
http://www.cherokeeforum.com/g/album/1725214
cruiser54 is offline   Reply With Quote Quick reply to this message
Unread 11-29-2012, 03:20 PM   #5
jahiatt
thanks
