1 ton install on Comanche - JeepForum.com
post #1 of 10 Old 08-11-2008, 07:06 PM Thread Starter
nortron
1988 MJ Comanche
I have recently acquired a 88 Comanche. I also conveniently have a set of full size axles from a 78 f250 from another build. I would like to put the two together and build a nice rig on a budget. my question is, what is the best way to go about marrying the two? Anything I need to look out for? what are everyone's thoughts on converting the coils in the front to a leaf spring setup? I have seen a couple rigs using waggy leafs and they seam to do well. example: http://www.pirate4x4.com/forum/showt...=232083&page=3
Thanks in advance for any insight provided.
nortron is offline
post #2 of 10 Old 08-11-2008, 07:10 PM
wil badger
Hope you can weld.............................................. .........................
This thread should help you for the front.I would think the rear is pretty self explanatory .
wil badger is offline
post #3 of 10 Old 08-11-2008, 07:21 PM Thread Starter
nortron
1988 MJ Comanche
awesome. exactly what i was looking for. the "google search" function wasn't helping me out very much.
nortron is offline
post #4 of 10 Old 08-18-2008, 11:15 AM
XJ2000
XJ2000's Avatar
Instead of converting the front to leafs, why don't you convert the front axle to accept coil springs. All you'd have to do is grind off the spring perches and weld on Coil Spring perches instead. I think that converting the front of an MJ to leafs would be too much work.
: 2000 XJ w/ 4.5" RE SF, Locked XJ D44 Rear, Locked D30, and a bunch of other things
Pavement Pounder: 2001 XJ Daily Driver, 2" BB, 245/70R16 AT's on Moabs
XJ2000 is offline
post #5 of 10 Old 08-18-2008, 11:58 AM
wil badger
Uhm I think you forget a few things there bud!
How about control arm mounts,both upper and lower as well as a track bar mount?
post #6 of 10 Old 08-18-2008, 12:17 PM
XJ2000
XJ2000's Avatar
DUUUUHHHHHHH
Been staring at this damn screen for waaay too long and definately didn't think before posting
XJ2000 is offline
post #7 of 10 Old 08-18-2008, 02:06 PM
Pete M
1988 MJ Comanche
TNT has some pre-fabbed trusses that include control arm mounts.
--Pete
-88 MJ; 4.0L, ex-2wd, TJ ax15/231, 78 Ford D44 w/spool, 9" w/posi, 33" trXus MTs, custom roll-bar/bumpers/etc.
Also an 86 MJ Metric ton and 2 '90 MJs
Projects/wheelin' pics: picturetrail.com/petermontie
My email:
ComancheClub.com/forums
Pete M is offline
post #8 of 10 Old 08-27-2008, 03:22 AM
Abstruse
Wow, and you'll do all this for far cheaper than a quote I was just given to put a new Dana 44 under the front and rear of mine. Just for the Custom Dana 44 axles with lockers (not installed) are going to run me $2900 for the rear, $4350 for the front...
email quote from http://www.foothilloffroad.com/ ...
A front axle in the configuration you're looking at will be around $4350, the rear would be around $2900. This gets you all new components, alloy shafts, bigger brakes, etc. The front would have the brackets you need for your suspension and the rear would have leaf spring hardware.
Haven't had any problems with that front Dana 30 but it always worries me, I'd love to upgrade my front and rear to the famed Dana 44 so many Jeep enthusiasts always seem to long for. I'm saving up now just to get the rear done first, but its going to be a while.
Abstruse is offline
post #9 of 10 Old 08-27-2008, 01:24 PM
Pete M
1988 MJ Comanche
A good alternative for upgrading the axles is the new M44 Mopar units. I heard that the fronts are really close to a bolt-in.
--Pete
My email:
Pete M is offline
post #10 of 10 Old 11-14-2012, 10:15 PM
bud97103
some full size fords have coils in the front with somewhat of the same set up as the jeep. i have hurd of people using them for an easyer swap... just something to look into...
bud97103 is offline
about to go buy a $250 comanche veritas4156 MJ Comanche Technical Forum 15 08-18-2009 12:44 PM
RHD Comanche Cupid MJ Comanche Technical Forum 1 05-20-2009 01:16 PM
86 Comanche MTtyer MJ Comanche Technical Forum 2 02-03-2008 06:34 PM
86 Comanche ksgrands MJ Comanche Technical Forum 24 01-15-2006 11:09 AM
Just got a Comanche Lewis MJ Comanche Technical Forum 3 02-25-2005 04:07 PM
