ZJ-TJ Coil Over Conversions - Page 2 - JeepForum.com
post #16 of 42 Old 09-26-2009, 09:24 PM
bobdog
Originally Posted by LMoscar45 View Post
I got crazy gains with the ZJ coils I got from auto zone. I paid $92 for Moog premium lifetime coils, and it lifted the front 3.5 inches....my factory front rubi coils are out back and are within 1/4 inch of the ZJ fronts...not bad but more lift than I really wanted--I did not expect that much.
I could use those rubi coils if there going to waste...
Will they fit a 99TJ?
Black Jeep Society
New Mexico Jeep Club
Atheist Jeep Society
Micro-Trailer Club
bobdog is offline
post #17 of 42 Old 09-27-2009, 07:29 AM
Photog2000
so...what about trac bar issues with this lift? I am getting a set of ZJ coils and want to make sure I have everything. I found an article but it was just too confusing because the guy was trying to explain the ZJ lift as well as kit lift in one article.
Photog2000 is offline
post #18 of 42 Old 09-27-2009, 10:16 AM
LMoscar45
A ZJ lift is nothing more than this:
1)taking a set of 1993-1998 V8 grand cherokee front coil springs and putting em' where your fornt springs are
2) You then either put your front springs where your rear springs are to level it out, or use the Ford Crown Victoria rear springs in your rear which does virtually the same thing.
I put my fronts out rear and am within 1/4" of the front. I did buy new Moog front coils for $92, they are very very stiff coils but ride very nice with my skyjacker nitro shocks. I don't even have a front bumper on right now to add weight and make them smoother. I doubt they will droop with weight since I'm 300lbs and can stand on my cross member and it only slouches 1/2 inch...smooth and tough.
Yes, you will definitely need a track bar to recenter your axle. Adding 3+ inches will pull your axle to the drivers side of your Jeep, so an adjustable track bar will solve that problem. Longer bump stops for the rear are necessary also.
You may also get vibes with this amount of lift. I tried to stay away from the vibrations by using this lift, but with this combo and a body lift I still got em in the rear. You can get a set of rear upper adjustable control arms to dial out the vibrations without going with a SYE. I'm lucky with a rubicon I don't need the SYE.
This setup worked good for me whie I was researching my ultimate goal. I am now taking this setup off to go Low center of gravity, and will be running 2 inches of lift with 35 inch tires. Going highline fenders. Good luck. I may throw the moog coils for sale on here (only 700 miles on em').
LMoscar45 is offline
post #19 of 42 Old 10-03-2009, 11:56 PM
rpiereck
Anyone got the part numbers for the Moog coils, both V8 ZJ and Crown Vic?
JKS Adjustable control arms - JKS 1.25" Body Lift - JKS 1" Engine Mount Lift
Old Man Emu 4" coils - Rancho 5000 shocks - Teraflex front adj trackbar - RE rear track bar bracket
33/12.5x15 Wrangler Duratracs - Tabor 12k Winch - Hella 500F Foglights
Hella Supertone Horns - Uniden CB radio
rpiereck is offline
post #20 of 42 Old 10-04-2009, 07:32 PM
Photog2000
I got mine done. I gained about 2-1/4" in the front and a full 3" in the rear. My rear shocks are maxed out. I need to get them changed as soon as possible, and I do have some vibes so I am going to lower the T case a bit.
post #21 of 42 Old 10-05-2009, 01:42 AM
rpiereck
I'm looking forward to doing this as I have JKS adj control arms, Teraflex adj track bar, and Rancho 5000 shocks ready to go. All I'll need is the springs, plus rear adj track bars and the sway bar discos. Part #s would help.
rpiereck is offline
post #22 of 42 Old 10-05-2009, 08:18 AM
LMoscar45
I have the box my coils came in and I'll check it later this afternon. I can't help out on the crown vic part numbers though--I'm faily certain its any mid to late 90's police interceptor model. I'm probably going to be throwing my moog coils up for sale if yer interested (I need less lift with highline fenders).
post #23 of 42 Old 10-05-2009, 09:31 AM
rpiereck
If you can find some cheap shipping to Alaska I might get them from you. Gimme a shipping quote by USPS Priority Mail and we'll talk. Living in AK shipping is always a byatch.
rpiereck is offline
post #24 of 42 Old 10-07-2009, 09:17 PM
Patton
Originally Posted by Photog2000 View Post
I got mine done. I gained about 2-1/4" in the front and a full 3" in the rear. .
Is that with ZJ v8 front with an extra isolator/ CV Police rear springs? I really am begining to wonder if I actually have Crown Vic rear springs. I was told they were but I have gotten over 1 full inch of lift more than others say they did.
94 YJ 4.0/3spd dana 60/44 w/35's 9" of suspension lift
Sold-06 TJ X 4spd auto 3.73
Patton is offline
post #25 of 42 Old 10-07-2009, 09:39 PM
Photog2000
Just the ZJ V8 springs. Not sure what you mean by extra isolators. My rears are the original TJ front springs.
post #26 of 42 Old 10-08-2009, 04:11 PM
Patton
That is what I was wondering.
Patton is offline
post #27 of 42 Old 12-18-2009, 02:00 PM
Dangermouse
Howdy y'all. At the moment I got the Rubicon Express budget lift and I want to raise it high enough to clear 33s. I use the jeep for trail roads and some mudding. I don't see myself rock crawling. So would I remove the spacers, keep the R.E. shocks, and replace my springs with the ZJ and CV springs? My jeep has the 4.0l six, an auto tranny, and a soft top.
Dangermouse is offline
post #28 of 42 Old 12-18-2009, 10:57 PM
Photog2000
Why not just add a 1.25" body lift and leave the pucks?
post #29 of 42 Old 12-18-2009, 11:04 PM
Dangermouse
I do want to go with stiffer springs than factory since I do plan on adding bumpers and a hard top. Originally I was saving up for an OME kit with a 1.25 body lift but times are tough now.
post #30 of 42 Old 12-19-2009, 12:14 AM
Chris_W_2k5
When i had that set up (V8 springs up front, TJ fronts in the back) I got bad vibes which even took out the pinion seal (thank god for drive train warantee ) T-case drop could have taken care of it though. The ride quality did suffer as it made it a rough ride. My current setup though is great, the front is still stiff but at least its a nice and in-expensive lift.
'96 stock ZJ
Originally Posted by Crashnburn80
...so assuming your Jeep is right-side-up you should be ok.
Chris_W_2k5 is offline
CJ-7 and cherokee conversions captinCJ-7 General Jeep & Off-Road Equipment 3 04-04-2008 07:45 PM
IPF H4 conversions slr001 Audio, CB & Ham Radios, GPS, & Electrical 3 05-02-2007 05:42 PM
Engine Conversions? BlackAce Engines & Drivetrain 3 03-22-2007 08:27 PM
delta h4 conversions? Maximummud Audio, CB & Ham Radios, GPS, & Electrical 2 03-03-2006 09:33 AM
COil conversions Joe jeep Tires & Wheels 6 02-19-2003 05:43 PM
