ZJ 3" lift - Junkyard style - Page 2 - JeepForum.com
post #16 of 41 Old 11-15-2010, 07:16 AM
Area.3.Fiftyone
F>R swap (V8 springs) will get you 3" every time. Been there, done that and it's well documented.
F150 springs will make it drive like a dump truck. The spring rate is totally wrong for a ZJ and that is well documented as well all over the interweb.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #17 of 41 Old 11-15-2010, 07:22 AM
Xerxes
those pics dont look like 3" to me. at least compared to mine
Originally Posted by melk:
"Either more or less lube may change the moaning!"
|::Sahara Owner::|
Xerxes is offline
post #18 of 41 Old 11-15-2010, 11:43 AM Thread Starter
neonhomer
Measured before and after at the fender lips....
I don't think the Jeep rides bad at all. I drove it to Tampa and back across I4, and didn't notice a rough ride... but then again my DD is a 04 Silverado w/ the HD towing package. It definatley rides stiffer than the factory ride, but it doesn't seem bad to me.
Now my friend did the same w/ his ZJ, and he used the 4WD F-150 front springs, and HIS jeep rides like a dump truck...... I used 2WD springs.....
I was contemplating moving the F150 springs to the back, and then getting a set of 5" lift springs for the front, but I really don't want THAT much lift.
BTW Xerxes - It looks like less lift because of the tires I have on it. Those are just a set of used 235/75 15 BFG Long Trail's. You look to have 31's on yours. My friend has 32's on his ZJ, and his looks like yours. There are pictures of his ZJ as well on my FB page...
neonhomer is offline
post #19 of 41 Old 05-12-2011, 08:04 PM
cali7312
I might try it, right now im on 3" spacers with zone shocks. but i might just spend the $$$ to get a 3.5" IRO
cali7312 is offline
post #20 of 41 Old 05-14-2011, 09:04 AM
1stblack97ZJ
Use V6 thunderbird front springs instead of f150 springs. The spring rate on the thunderbird spings is closer to stock, and they will net you around 3.5" of lift.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
1stblack97ZJ is offline
post #21 of 41 Old 05-17-2011, 01:55 PM
corndogduff
Is this true? I have access to a v6 bird thats being parted, what years work?
Duff.
(broken)98 ZJ 5.9
UT Jeepcrew #13
NIGHTCREW
corndogduff is offline
post #22 of 41 Old 06-01-2011, 09:59 AM
1stblack97ZJ
you have PM
sorry it took so long to get back to you.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #23 of 41 Old 07-04-2011, 03:16 PM
MuddSlutt
you have PM
can you please let me know what years also... thank you
01 WJ 4.0 ((New Toy))
98 ZJ 5.9 Limited ((SOLD))
MuddSlutt is offline
post #24 of 41 Old 07-04-2011, 06:00 PM
rooster51
Ive got V8 fronts in the rear w/ 3 1/2" and about 100lbs. of crap in the back.
I removed about 5 sets os V8 fronts at the JY, measured them all and kept the 2 longst springs. No pics, Im at work.
Terry
rooster51 is offline
post #25 of 41 Old 07-05-2011, 06:48 PM
1stblack97ZJ
You have PM
That's good to know, hopefully the v8 springs I got will work just as well for me.
For future reference, here is the info on the thunderbird springs:
Front coil springs from a 3.8 V6 equipped Ford Thunderbird/Cougar offer 3-4in of lift and the softer ones noted below ride and flex like stock XJ coils.
83-88 TBird, Cougar = more lift
89-97 TBird, Cougar = less lift
Spring ratings:
Front: 223-282 lb./in. 3.8 liter V6 *closest to XJ ratings* these coils are used on the bare bones basic cars
Front: 349-403 lb./in. 3.8 liter SC Loaded with every option, very stiff ride
Front: 270-330 lb./in V8 Medium ride
I'll update this thread after I get the thunderbird springs and install the lift.
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #26 of 41 Old 07-12-2011, 03:12 PM Thread Starter
neonhomer
I think this is a different pic...
NeonHomer
Mid-Florida Jeep Club - Member
1996 Jeep Grand Cherokee, 4.0L/42RE/242 - Rebuilt motor w/ Comp cam (4/12), 3.5" Junkyard F>R lift, 31x10.5.x15 M/T's, Spartan Locked D44a, TC & tank skids, F&R adj trackbars, V8 steering arms
Galaxy DX99V CB, 102" SS Whip, Yaesu FT-2900R 2m, Larsen 1/4w mag mount, Sony HU, Massive 3way - F Door, Pioneer 3way - R Doors, MB Quart ONX304 Subs (x2), Lanzar 1600w amp.
"No Matter Where You Go... There You Are."
"Oh me oh my a lovely day is dawning. Oh what a joy I didn't wake up dead. So I can go to work and then resume my yawning, and get my sleep on site instead of in my bed" - Daria Morgendorffer (with my twist)
post #27 of 41 Old 07-24-2011, 07:58 AM
1stblack97ZJ
you still at about 3" all around?
1997 ZJ Laredo
4" Lift
32s
Plenty of lights
post #28 of 41 Old 03-16-2012, 08:55 PM
jtackerman28
I know its an old thread but did you replace the trackbars with adj. ones when you did the swap?
jtackerman28 is offline
post #29 of 41 Old 04-22-2012, 07:35 PM
Mannyssj13
What kinda rear axle is on there?
Mannyssj13 is offline
post #30 of 41 Old 04-29-2012, 11:34 AM Thread Starter
neonhomer
At first, no... but I have them now. My front axle only needed to be shifted over by about 1/8". My rear needed to be shifted about 1/16".....
My front axle is the stock Dana 30. I had the U-joint axleshafts, but I switched to the CV style. I still have my U-joint shafts, but I need a end for one of them because I broke the ABS tone ring on it. My rear axle is a Dana 44a w/ an Aussie Locker.
My lift is still right around 3-3.5"...
As for the shocks I use... they work, but they wear out quickly for the fronts. The rears have held up pretty good. I have the lifetime warranty shocks, so when they wear out, I just clean them up and take them back. LOL...
NeonHomer
WJ Junkyard 6" rear coils. iluvtruenos Cheap Tricks & Fixes 36 04-06-2013 06:05 AM
Aftermarket "TJ style" switches Slithering_Joe Audio, CB & Ham Radios, GPS, & Electrical 23 01-18-2012 04:09 PM
Cheap Junkyard Lift? Rustbucket83 Cheap Tricks & Fixes 11 02-24-2009 11:57 AM
anything bad about teh "old style" ARB got_4_lo General Jeep & Off-Road Equipment 5 06-14-2006 02:58 PM
Lift kit Africa style?? Baas Tires & Wheels 4 07-09-2004 12:32 AM
