Zinc Anodes - Combating chassis and body/component corrosion in winter - JeepForum.com
post #1 of 2 Old 08-01-2012, 02:29 AM Thread Starter
jamesmc
For those that live in areas that use salt on the roads in winter you can help prevent corrosion to mild steel and aluminium components on your Jeep by adding a couple of small blocks of a zinc to the underside of the Jeep bonded electrically (via a grounding strap/wire) to the chassis. Marine grade zinc blocks will be OK as a source material.
When the whole underside (chassis & zinc blocks) is wet with salty water, a low voltage electrical circuit will be formed. The zinc blocks will act as a sacrificial anode and help protect Mild Steel & Aluminium components from the effects of galvanic corrosion.
It'll make no difference in the dry, but the zinc block will do no harm either.
If you notice (in the winter) that the blocks are getting a whitish powdery looking coat on them (not snow!) then they are corroding and are doing their job! Keep them free from oil & paint or they won't work properly.
jamesmc is offline
post #2 of 2 Old 08-11-2012, 03:08 PM
grymsr
Vintage Member
grymsr's Avatar
I assume you have done this to yours. Got any pics?
How's that Hope and Change workin for ya?
Black Jeep Club v1.0 and v2.0 #1776
2004 Rubicon
2013 JKU Sport
grymsr is offline
Zinc Anode in Radiator (thoughts/opinions) RockJeepTJ Engines & Drivetrain 7 05-11-2013 04:48 AM
Using Zinc to stop rust 92XJCowboy Cheap Tricks & Fixes 3 01-17-2009 09:09 AM
black zinc ancestralworm Tires & Wheels 0 01-23-2008 08:52 AM
Zinc and por15 for battling rust The_'ster General Jeep & Off-Road Equipment 3 02-26-2006 10:49 AM
Zinc Plated vs. Stanless Steel Bolts? Shawno General Jeep & Off-Road Equipment 4 07-06-2003 06:53 PM
