Yj lift - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Yj lift
End of Summer Sale, 20% OFF!2007 - 2011 Jeep JK Long Arm Lift KitsIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 05-02-2014, 03:49 PM   #1
joey5639
Yj lift
I'm looking to soa my 95 yj wrangler but I'm not sure what I'd need to get for all this. Also my jeep is lifted already 2.5" rough country . So my question is would I be able to use the 2.5 leaf springs for the soa if so how much of a lift would I have or should I look for stock leaf springs
joey5639 is offline   Reply With Quote
Unread 05-07-2014, 12:19 PM   #2
YJacob
YJacob's Avatar
You would be able to use them, but would have around 7 inches of overall lift depending on spring condition. This has been done many times, and you could use the search function and find all the answers. Good luck!
YJacob is offline   Reply With Quote
Unread 05-09-2014, 08:16 PM   #3
schitzangiggles
King of Macastan
schitzangiggles's Avatar
Give the Rough Country springs some time, they will be negative arched before you know it.
Joey, have you searched the SOA threads in the FAQ in the YJ section? Because there is a lot more (especially $$) that goes into a viable and more importantly, SAFE SOA lift. It is more than simply moving the springs. I do have a Rubicon Express SOA kit that is NIB I bought a few years ago before I decided to go LCOG instead of SOA.
"Axeheads are supposed to be sharp, but you are one blunt tool."
FLynes
If you love wealth more than liberty,the tranquility of servitude more than the animating contest of freedom, go home from us in peace. We seek not your counsel nor your arms. Crouch down and lick the hand that feeds you. May your chains sit lightly on your shoulders and may posterity forget that you were our countrymen.
-Samual Adams
A government big enough to give you everything you want is big enough to take everything you have.
Thomas Jefferson
Calling Illegal Aliens "Undocumented Immigrants" is like calling drug dealers "Unlicensed Pharmacists"
Nemo Me Impune Lacessit
"No one provokes (attacks) me with impunity".
"Your right, the Tea Party and the OWS are the same, just like the America Revolution and the French Revolution were the same. The only problem is the American Revolution ended with Liberty, Freedom, Justice for all and a shining light upon a hill. The French Revolution ended with lynchings, guillotines, murder and socialism. So yeah, I could see how one could confuse the two..."
Mac Wilson
schitzangiggles is offline   Reply With Quote
Unread 05-16-2014, 10:07 AM   #4
joey5639
What is lcog? So is doing the soa with what I have a bad idea? 7" seems like a huge lift . What would you guys recommend I do?
Unread 05-16-2014, 10:09 AM   #5
joey5639
What is lcog? So is using what I have a bad idea 7" seems like a crazy lift? What would you guys recommend I do then?
Unread 05-16-2014, 03:05 PM   #6
schitzangiggles
King of Macastan
LCOG= low center of gravity
Like being able to use 36" tires with a 2" suspension lift (no body lift at all) and SUA (spring under axle)
FLynes
-Samual Adams
Thomas Jefferson
Mac Wilson
Unread 09-18-2014, 08:09 AM   #7
Ws349
Originally Posted by schitzangiggles
LCOG= low center of gravity Like being able to use 36" tires with a 2" suspension lift (no body lift at all) and SUA (spring under axle)
Do you have a build thread for that beauty? How did you fit everything in there?
Ws349 is offline   Reply With Quote
Unread Today, 07:09 PM   #8
Burlbook48
Burlbook48's Avatar
Hey Mac, what material are you using to extend the tire coverage of your fender flares?
Joey, listen to what Mac said. Properly done, new springs will be a small, small portion of the total cost of going SOA. This is not a mod on which to cut corners.
That said, my rig is SOA with 1.5" RE SOA springs and was on 33" tires. It's tall enough to make it awkward to enter my heep, and I'm 6'1". My 5 foot nothing daughter almost needed a stirrup. Now that I've gone to 37" rubber, I'm getting her a footstool as a joke gift.
Remember, taller means a higher center of gravity. Consider what your width will be. Planning on different wheels with a different offset to widen your stance?
You have to start somewhere to get to the middle of nowhere.
Burlbook48 is online now   Reply With Quote
