Yj to cj heat conversion? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Yj to cj heat conversion?
Corbeau Seats & Harness from CCOR!Win a $250 Gift Card to ZoneOffroad.com - 4th of July FaceRuffstuff Axle Simple Swap Kit!
Unread 06-29-2015, 09:07 PM   #1
Brian79cj-7
Is it at all possible to change the connections over to CJ pull push knobs I'm good with fabricating stuff just need ideas and not to mention, this is the kit Jeep doing a full restore. Someone already started a YJ tub swap, this is what I got the use with a little budget.
New on here just want to say thanks to all for all the information don't know what I'd do without you!
Brian79cj-7 is offline   Reply With Quote Quick reply to this message
Unread 06-29-2015, 09:21 PM   #2
Brian79cj-7
It looks like somebody put in a heater cable so that part is there I have a YJ to compare to. The defroster is fairly easy to figure out a bracket but the upper fresh air vent with the vacuum canister is the one I'm little stumped on
