YJ 15 to 20 gallon tank conversion - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > YJ 15 to 20 gallon tank conversion
RIGID LED Light Blowout Sale - All Sizes, All Series, all ECGS Black Friday Sale!!6th Annual, Beat Your Wife to the Credit Card Sale!
Unread 10-31-2004, 10:36 AM   #1
sjlplat
Common modification for '91 to '95 YJ's. Chrysler used the same tank in all of them to cut costs, and installed a longer tube in the filler to displace 5 gallons if you didn't purchase the 20-gallon tank option Here's a pretty good writeup:
http://www.4x4wire.com/jeep/tech/fuel/15to20gal/
sjlplat is offline   Reply With Quote Quick reply to this message
Unread 10-31-2004, 12:48 PM   #2
2muchfun
The only thing I will add to that write up is:
1. If you just remove the license plate, there are access holes to the screws to remove the whole assembly without fighting the spring load like a mouse trap.
2. That Tube is NOT easy to get out of the hose, be patient and try not to damage the hose.
SoCal Jeep Club Member #11
2muchfun is offline   Reply With Quote Quick reply to this message
Unread 11-03-2004, 01:53 PM   #3
mYJ
That tube IS a PITA to remove... prepare for some scratched hands. Once I finally got it out I didn't cut it and return it, just threw it out. No problems four months later and the 33% increase in range is great!
-Jeffrey-
[SIZE=1]92 YJ 2.5, OME, Flat Fendered, 31" Big O XTs, Crager Soft 8s, Posi-Lok, no sway/track bars, Exide Orbital, K&N, 4.0 TB & TBS, Mopar Performance Cam, Glass pack & Hi-Flow cat, Grant GT Removable Wheel, Tuffy Console, Other Stuff.[/SIZE]
[FONT=Impact][SIZE=2]Black JeepClub V2.0 #33[/SIZE] [/FONT][FONT=Tahoma] - Me & Roy[/FONT]
mYJ is offline   Reply With Quote Quick reply to this message
Unread 12-31-2004, 11:06 AM   #4
neZZr
Lifted/Locked/Rolled/Sunk
neZZr's Avatar
Anyone know if any of this is true for the TJ as well?
My '05 Rubi could seriously use some more range, but I don't much care to strap a gerry can on the back
*EDIT*
Just looked in DCX, found I already have a 19 gallon tank! (Code NF1S 19 GALLON W/TETHERED CAP FUEL TANK)
No wonder you guys with the 15gal tank need the mod!!
My Hummer Hole video
SIRA 4x4 club
I'll be Savvy someday!
neZZr is offline   Reply With Quote Quick reply to this message
Unread 12-31-2004, 03:46 PM   #5
BigWaylon
tubework is cool...
BigWaylon's Avatar
*EDIT*
it can be done on a TJ, but in a different way...
'99 or '00 was the last year of the 15-gallon, though...
I did the mod on my '99, and it holds more fuel than the 19-gallon that came in my '01...
Greg
2001 TJ 60th Anniversary Edition (details in Profile)
www.carolinarockshop.com
All the pics I have...including a Table of Contents
BigWaylon is offline   Reply With Quote Quick reply to this message
Unread 01-01-2005, 12:00 PM   #6
US1
Being a Jeep owner now for 2 months, I just read and did this modification just yesterday. Took me about 1 hr max. I just left the tube out completely. I just worked from underneath, w/o removing the license plate and filler neck. Didn't see the advantage of removing those parts. Can not believe the difference it made. Just got back from a 140 mile road trip and the gauge 'just' started to finally move.
Thanks for the tip.
'93 w/2.5L
US1 is offline   Reply With Quote Quick reply to this message
Unread 01-05-2005, 11:10 AM   #7
Micah
anybody know of a write up on how to do this to a tj?
Micah is offline   Reply With Quote Quick reply to this message
Unread 01-05-2005, 10:58 PM   #8
BigWaylon
tubework is cool...
BigWaylon's Avatar
you ought to be able to find what you need in one of these...
any other questions, just shoot me a PM...
http://www.jeepforum.com/forum/f9/15-gallon-tank-vs-19-gallon-tank-83219/
http://www.jeepforum.com/forum/f9/15-19-gastank-conversion-84261/
this link is buried in there, and is a decent how-to with pics:
http://www.gottrail.com/TJ/TJfueltankconversion.html
...I would just advise not to follow his exact instructions, as he cut off both tubes inside the tank...all you need to do is cut the smaller diameter one...the other has a "ping-pong" ball in the end that you can feel, and is the anti-siphon valve...
Greg
Unread 11-23-2005, 01:17 AM   #9
irdaniel
15-20
I did this mod, and ran out of gas while pulling into the pumps...it took 20.6 gallons of gasoline....wow. True Story!
irdaniel is offline   Reply With Quote Quick reply to this message
Unread 11-23-2005, 11:45 AM   #10
theviper90210
is it better to just remove the tube or take it out and cut it like in the write up, what do yall sugest and also how does it affect your gas guage? Thanks
theviper90210 is offline   Reply With Quote Quick reply to this message
Unread 11-23-2005, 04:09 PM   #11
saminwy
i just left the tube out. as far as the gas guage, it will just stay pegged at full for longer. then will read the same as it would have as a 15 gallon tank(ie: 1/2 tank would be 7.5 gallons, not 10)
saminwy is offline   Reply With Quote Quick reply to this message
Unread 12-05-2005, 08:00 PM   #12
Mr.B
Wot's...uh The Deal?
Mr.B's Avatar
Hey I just did this mod last night. The vent tube was a real pain to get out, like you said. I sprayed some Pam on it(with my finger jammed in the hole) after it had come out a little. I'm not sure if it helped though. Now I'm waiting for the loan to come through so I can fill the tank.
White '94 YJ 2.5L 5 speed, 35" BFGs KM2's, 5" lift, Mark VII 2 speed fan, Milemarker PE8000, Front Aussie Locker, Power steering conversion, '98 Cavalier seats, MORE Boomerangs in front, 136 amp ZJ alternator, JB conversions SYE, Tom Woods custom drive shaft, 8.8 with ARB, 4.88 gear ratio, Teralow
My Jeep
'89 XJ Laredo Bone Stock
Member:The Wrecking Crew
Ham license:
KB6(tooeasytosearch)
Everyone is Welcome
www.rubiconramblers.com
Originally Posted by Major Sanderson
You have no respect for excessive authority or obsolete traditions. You're dangerous and depraved, and you ought to be taken outside and shot!
Originally Posted by Beefstew
I may have proven that I am in fact an idiot, by all of your standards...
Originally Posted by ritjobbie View Post
Mr.B's post gets you as close to Buddha as you can get on JF...
Mr.B is offline   Reply With Quote Quick reply to this message
Unread 08-02-2007, 02:52 AM   #13
BitterOso
Junior Member
BitterOso's Avatar
i did this mod today, and ended up with a nasty cut (all the way to bone) on my wrist when my pliers slipped off the vent tube. my wrist hit the edge of the cut-out for the gas tank access. anyone who is planning this mod, might want to tape some padding along that edge.
BitterOso is offline   Reply With Quote Quick reply to this message
Unread 10-15-2011, 06:15 PM   #14
AZdEvilYJ
Garage Junkie
AZdEvilYJ's Avatar
Just did this today! Eaaasy mod! Took less than an hour
AZdEvilYJ is offline   Reply With Quote Quick reply to this message
Unread 09-15-2014, 09:39 AM   #15
TennesseeYJ
I know I'm bringing this thread back from dead. But, I did this mod to my YJ .. The tube is a B!t%H to get out. But I won the battle!! Yeaaa .. for longer range between fill ups! Here is the vid:
1991 Jeep Wrangler YJ, <-- My Jeep is a pickpocket!!
1984 Mustang GT Top 5-Speed <-- Running soon hopefully
2003 Honda Shadow Spirit 750, 1994 Suzuki Katana 600, 1980 Yamaha XS650 <-- Ripped apart and under the knife .. Chopped, bobbed & mono shocked. I got too many toy$$$!!!
TennesseeYJ is offline   Reply With Quote Quick reply to this message
