XJ XJ XJ Cherokee Cheap Mods XJ XJ XJ - Page 22 - JeepForum.com
post #316 of 416 Old 10-28-2011, 08:09 AM
XJeshua
Thanks, will do, can't wait to really get my feet wet, or muddy rather!
'98 XJ
XJeshua is offline
post #317 of 416 Old 10-28-2011, 10:51 PM
PlatinumNiner
Originally Posted by mikeredjeep View Post
Would the box your making fit in an xj or is it just for the zj?
It's built for an XJ not a ZJ No way you can fit a 12" sub inside the 1/4 panel on a ZJ. I have one built and ready to go with a 12" MB Quart sub in it. PM me if your interested.
PlatinumNiner is offline
post #318 of 416 Old 11-01-2011, 11:20 PM
gabejeep
1997 XJ Cherokee
Custom Gauge in Ashtray on 97-01 Cherokee XJ
Here is a modification I just did to my XJ. I put a transmission temperature gauge in the area that houses the ashtray. Gaugeplates.com makes a custom plate that fits this area.
I did have to take my dremel saw and cut out the recessed area that houses the actual removable ashtray. However, it wasn't that big of a deal. The gaugeplate then had 3M adhesive tape which I used to seal the plate.
Here are some photos...
gabejeep is offline
post #319 of 416 Old 11-02-2011, 12:07 AM
justanotherjpr
Nice work!
So do you actually hear your thoughts in your head or is it just sort of a dull roar before you smash your face into your keyboard and just submit whatever dumb **** ended up on the page?
justanotherjpr is offline
post #320 of 416 Old 11-02-2011, 08:32 AM
Sirus789
1997 XJ Cherokee
Looks good, I put oil psi and trans temp on the a pillar. What kind of gauge did you use? Mechanical or electronic?
97 XJ Country...Super Clean!
1992 Dodge W150 5" lift, 35s
Sirus789 is offline
post #321 of 416 Old 11-02-2011, 10:16 AM
gabejeep
1997 XJ Cherokee
The gauge I used was a Sunpro gauge I purchased at Pep Boys. I bought a really fancy gauge from Marshall Instruments but it turned out to be defective. I think the cheap gauge from Pep Boys goes better with the Cherokee Decor anyway.
The gauge is both a mechanical and electrical gauge from what I understand. It can be used for either setup.
Gabe
gabejeep is offline
post #322 of 416 Old 11-02-2011, 02:41 PM
Sirus789
1997 XJ Cherokee
cool deal, its a must for an AW4 and wheeling, them little buggers get HOT even with a trans cooler.
Sirus789 is offline
post #323 of 416 Old 11-02-2011, 02:44 PM
gabejeep
1997 XJ Cherokee
Anyone have any idea what the average running temperature and/or low and high temperature range for a AW4 transmission on a 97-01 XJ?
gabejeep is offline
post #324 of 416 Old 11-02-2011, 02:48 PM
Sirus789
1997 XJ Cherokee
from what ive noticed in mine it will run usually around 140-180 on a warm day, but sitting in traffic sometimes 200+ but then i just turn my fan on and she cools down. but its just like anything else 220-230 i would be worried.
Sirus789 is offline
post #325 of 416 Old 11-02-2011, 02:53 PM
gabejeep
1997 XJ Cherokee
That's a huge range. 200 seems pretty high doesn't it? Im convinced my old transmission blew out because it overheated. I'd like to prevent this new one from the same fate.
Since I put on my transmission cooler mine has been running around 120 degrees on average. I notice it starts to heat up when your idling like you said. I'm just wondering how much it will heat up when towing a small boat (1,800 lbs).
gabejeep is offline
post #326 of 416 Old 11-02-2011, 06:35 PM
Sirus789
1997 XJ Cherokee
Forgot to mention I'm pushing a front JCR pre runner winch bumper with a winch and cover. So my airflow is restricted some. But I plan on doing hood vents to get rid of the heat soak issue
Sirus789 is offline
post #327 of 416 Old 11-02-2011, 09:18 PM
gabejeep
1997 XJ Cherokee
Woodgrain Dash Trim Console on a 97-01 XJ
I found a woodgrain dash trim console on eBay that was originally in a limited edition XJ. The sides of the panel were a kind of greyish color so I painted them black to match my dash. I like the way it came out. It looks a little bling, but I think it breaks up the black.
What do you guys think?
Gabe
gabejeep is offline
post #328 of 416 Old 11-03-2011, 09:32 AM
dukie564
1995 XJ Cherokee
looks great!
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #329 of 416 Old 11-03-2011, 10:12 AM
95whiteXJ
1991 XJ Cherokee
<img src="http://www.jeepforum.com/forum/attachment.php?attachmentid=298608"/>
What kind of pillar did you gave to buy? Or do they actually make one for our XJ's?
95whiteXJ is offline
post #330 of 416 Old 11-03-2011, 10:15 AM
95whiteXJ
1991 XJ Cherokee
Gabe
Looks good buddy!! I put a woodgrain dash bezel in my white '95 4dr DD....breaks up the grey.
Nice detail work on painting the grey, black.
Currently Active Users Viewing This Thread: 5 (0 members and 5 guests)
Cheap yj mods love2crwl Cheap Tricks & Fixes 36 02-04-2017 05:22 PM
cheap 4.0 mods? redneckwithajeep Engines & Drivetrain 17 01-04-2015 02:33 PM
cheap xj mods?? hoot20 Cheap Tricks & Fixes 0 05-25-2009 02:52 PM
CJ-7 Cheap Mods GoldenEagleGa Cheap Tricks & Fixes 1 02-06-2009 11:53 PM
Cheap exhaust mods? apoto11 Cheap Tricks & Fixes 20 10-16-2008 05:23 AM
