XJ XJ XJ Cherokee Cheap Mods XJ XJ XJ - Page 20 - JeepForum.com
post #286 of 416 Old 05-04-2011, 09:33 AM
PlatinumNiner
Not installed yet but will be soon. Ill get more pictures along the way.
PlatinumNiner is offline
post #287 of 416 Old 05-04-2011, 12:51 PM
95whiteXJ
1991 XJ Cherokee
Originally Posted by PlatinumNiner
Built this box from 1/2" and 3/4" MDF. Whole box is sealed with resin and the curve is fiberglass which was coated with 3 coats of resin inside and out. Can be used with a 12" sub with up to 4" of mounting depth. I just ordered a shallow 12" MB Quart subwoofer for it. 3" mounting depth! This will be wrapped in carper and put inside the passenger 1/4 panel I will then make a panel to cover it out of 1/4" wood, round the edges, and wrap it in gray speaker grill cloth. Ill post more pictures along the way. If i get enough interest i may start building these boxes to sell. Id sell them with no subwoofer. I can cut a hole for an 8" 10" or 12" woofer. Buyer will have the option.
Interested!! Price?
95whiteXJ is offline
post #288 of 416 Old 05-04-2011, 12:59 PM
PlatinumNiner
For just the box with no sub or anything it would be in the $100 range. I wana get this installed and perfect fit before that though. Ill work out all the bugs know what i mean.
post #289 of 416 Old 05-04-2011, 03:45 PM
95whiteXJ
1991 XJ Cherokee
Totally understand brother....I wouldn't want a grille, as I will have my own....$100 range is not too shabby
post #290 of 416 Old 05-04-2011, 04:57 PM
Hardt114
also interested...update us with pics and info once you get it installed
Hardt114 is offline
post #291 of 416 Old 05-04-2011, 05:30 PM
95whiteXJ
1991 XJ Cherokee
x2
post #292 of 416 Old 05-04-2011, 05:36 PM
PlatinumNiner
will do guys thanks
post #293 of 416 Old 05-24-2011, 01:04 PM
muddin92cheroke
Originally Posted by platinumniner View Post
and the check engine light which puts your computer in limp mode (diagnostic mode) and hurts your gas mileage and performance.
accually it will only turn on the cel if its a 97 or newer, because anyhting after 97 have upper and down stream o2 sensors, before 97(obdii) only had the up stream o2
IF MUD AINT FLYING YOU AINT TRYING!!!!!
muddin92cheroke is offline
post #294 of 416 Old 05-24-2011, 01:20 PM
dukie564
dukie564's Avatar
1995 XJ Cherokee
1996-2001 is OBDii
1995 XJ Cherokee Sport
4.5" Homebrew Lift, 4.0L HO I-6, AX-15, NP231, D30(Open)/C8.25(Locked)
33x12.5 Mickey Thompson Baja MTZ Tires, 309,000 mi and runnin' strong
dukie564 is offline
post #295 of 416 Old 05-28-2011, 09:24 PM
PlatinumNiner
Correct 1996+ are OBDII
post #296 of 416 Old 05-28-2011, 11:21 PM
keepishop
1989 XJ Cherokee
Posting to keep the thread alive.... A little cubby hole net.
Current: Black 89 limited, dakota bastard pack, zj coils, 1.5" lift, open cooling swap,
Rest in Pieces: Red 1990 cherokee dana30/8.25 - v8 zj coils & s10 bastard pack 2.5" lift - 31x10.5r15 tires - v8 zj tierod
Originally Posted by talentjeep View Post
Bleed or Quit.
jf irc @ irc.freenode.net #jeepforum
keepishop is offline
post #297 of 416 Old 05-31-2011, 11:40 AM
muddin92cheroke
Originally Posted by 96JXJ View Post
Hood vents.
JIM.
did you notice any difference in engine temp??
post #298 of 416 Old 05-31-2011, 11:46 AM
CJ258
1974 CJ5
I put hood vents like that on a Toyota p.u. I had. I had a Chevy 4.3 in it and the vents really helped to pull heat out of the engine compartment . I believe it helped the radiator by drawing air thru with vacuum. Need to do that to our Cherokee.
CJ258 is offline
post #299 of 416 Old 05-31-2011, 11:47 AM
muddin92cheroke
Originally Posted by dukie564 View Post
1996-2001 is OBDii
it depends on the vehicle manufactor because alot of them didnt go to obdII untill the 1997 model
post #300 of 416 Old 05-31-2011, 11:51 AM
dukie564
dukie564's Avatar
1995 XJ Cherokee
well we're talking about jeep only...
dukie564 is offline
cheap 4.0 mods? redneckwithajeep Engines & Drivetrain 17 01-04-2015 03:33 PM
Cheap yj mods love2crwl Cheap Tricks & Fixes 32 01-17-2013 01:33 AM
cheap xj mods?? hoot20 Cheap Tricks & Fixes 0 05-25-2009 03:52 PM
CJ-7 Cheap Mods GoldenEagleGa Cheap Tricks & Fixes 1 02-07-2009 12:53 AM
Cheap exhaust mods? apoto11 Cheap Tricks & Fixes 20 10-16-2008 06:23 AM
